[petsc-users] Determine the positive definiteness
w_ang_temp w_ang_temp at 163.com
Fri Jan 11 11:51:43 CST 2013
Yes, it isanecessarybutnotsufficientcondition.
At 2013-01-11 03:56:25,"Barry Smith" <bsmith at mcs.anl.gov> wrote:
>   If cg says indefinite then it is indefinite
>   if cg runs and does not say it is indefinite it may still be indefinite (though probably not all that likely).
>   Barry
>On Jan 10, 2013, at 11:46 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jan 10, 2013 at 10:44 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>> Hello,
>>     I want to determine the positive definiteness. So I want to know
>> if it is a right way.
>>     I use "-ksp_type cg -pc_type none". You know, CG does not work for
>> indefinite matrices. I get "Linear solve did not converge due to
>> DIVERGED_INDEFINITE_MAT". From the information, I think it is indefinite.
>> Is it a right way?
>> Its not full proof, but it could be a diagnostic.
>>   Matt
>>     Thanks.
>>                                             Jim
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130112/3443c49c/attachment-0001.html>
