[petsc-users] Petsc 3.3.p5 with HYPRE 2.9.0b
John Fettig john.fettig at gmail.com
Thu Jan 10 13:09:57 CST 2013
On Thu, Jan 10, 2013 at 1:10 PM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> > On Thu, Jan 10, 2013 at 5:15 PM, John Fettig <john.fettig at gmail.com>
> wrote:
> >> FWIW, hypre 2.8.0b can be made to compile in windows with MSVC 10 in
> cygwin.
> >> John
> > Thanks, yes, I know, but I must compile it natively using MSVC, its
> > beyond my control.
> > PS/ I managed to compile 2.7.0b on my own with lots of hacks, 2.8.0b
> > resists, as posted, 2.9.0b builds smoothly using cmake.
> Maybe I was not precise enough: what you refer to as "can be made to
> compile in windows with MSVC 10 in cygwin" is not fully true: it means
> compiling with MSVC but linking with cygwin, resulting in a cygwin
> dependency, which is ruled out by the owner of the project that I am
> working on.
I'm not sure I understand.  The resulting library has no dependency on
cygwin, and is compiled entirely by cl.  The library itself is built by
"lib", the microsoft library tool.  Are you saying that requiring cygwin as
the build environment for hypre is unacceptable?
John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130110/75c62c4c/attachment.html>
