[petsc-users] binary vtk viewer DMDA
Kevin Green kevin.richard.green at gmail.com
Thu Jan 10 11:05:02 CST 2013
Personally, I think it should probably be disabled... AFAIK # works for
comments, and what are the advantages of having multiple comment characters?
On Thu, Jan 10, 2013 at 12:00 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Oh, this is the problem with allowing % for comments, but not parsing
> quotes. Last time we discussed this, I thought we decided that % should not
> be a comment character. Should we disable it?
> On Thu, Jan 10, 2013 at 10:57 AM, Kevin Green <
> kevin.richard.green at gmail.com> wrote:
>> I was just playing around with this in the recent petsc-dev, and noticed
>> the following:
>> It works fine when provided from the command line, but when used in a
>> file with -options_file, I get the error:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR:   !
>> [0]PETSC ERROR: -ts_monitor_draw_solution_vtk requires a file template,
>> e.g. filename-%03d.vts!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Development HG revision:
>> 117b19d7e9971ca4c134171ccd46df7d0d54c1e1  HG Date: Thu Jan 10 09:41:10 2013
>> -0600
>>  [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: ./cortex on a arch-linux2-c-debug named
>> kg-ThinkPad-X220-Tablet by kg Thu Jan 10 11:44:39 2013
>>  [0]PETSC ERROR: Libraries linked from
>> /home/kg/libs/petsc-dev/arch-linux2-c-debug/lib
>> [0]PETSC ERROR: Configure run at Thu Jan 10 11:05:06 2013
>> [0]PETSC ERROR: Configure options --with-debugging=1 --with-x=1
>> PETSC_ARCH=arch-linux2-c-debug
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: TSSetFromOptions() line 220 in src/ts/interface/ts.c
>> [0]PETSC ERROR: main() line 225 in src/main.c
>> This is the first time I've ever had a difference between command line
>> and -options_file behaviour... Is it a bug, or is there something special
>> about using string commands in -options_file that I just don't know about?
>> Cheers,
>> Kevin
>> On Thu, Jan 10, 2013 at 1:12 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> On Wed, Jan 9, 2013 at 3:36 PM, Blaise A Bourdin <bourdin at lsu.edu>wrote:
>>>> Wouldn't it be trivial for a DMDA?
>>> It should be, but I was trying to buy some time because I was picking up
>>> projects at a seemingly exponential rate this week, despite prior
>>> obligations. ;-)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130110/992da621/attachment.html>
