[petsc-users] binary vtk viewer DMDA
Kevin Green
kevin.richard.green at gmail.com
Thu Jan 10 10:57:04 CST 2013
I was just playing around with this in the recent petsc-dev, and noticed
the following:
It works fine when provided from the command line, but when used in a file
with -options_file, I get the error:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: !
[0]PETSC ERROR: -ts_monitor_draw_solution_vtk requires a file template,
e.g. filename-%03d.vts!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
117b19d7e9971ca4c134171ccd46df7d0d54c1e1 HG Date: Thu Jan 10 09:41:10 2013
-0600
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./cortex on a arch-linux2-c-debug named
kg-ThinkPad-X220-Tablet by kg Thu Jan 10 11:44:39 2013
[0]PETSC ERROR: Libraries linked from
/home/kg/libs/petsc-dev/arch-linux2-c-debug/lib
[0]PETSC ERROR: Configure run at Thu Jan 10 11:05:06 2013
[0]PETSC ERROR: Configure options --with-debugging=1 --with-x=1
PETSC_ARCH=arch-linux2-c-debug
[0]PETSC ERROR:
[0]PETSC ERROR: TSSetFromOptions() line 220 in src/ts/interface/ts.c
[0]PETSC ERROR: main() line 225 in src/main.c
This is the first time I've ever had a difference between command line and
-options_file behaviour... Is it a bug, or is there something special about
using string commands in -options_file that I just don't know about?
Cheers,
Kevin
On Thu, Jan 10, 2013 at 1:12 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Wed, Jan 9, 2013 at 3:36 PM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
>> Wouldn't it be trivial for a DMDA?
> It should be, but I was trying to buy some time because I was picking up
> projects at a seemingly exponential rate this week, despite prior
> obligations. ;-)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130110/4a63ba8e/attachment.html>
