[petsc-users] Dealing with 2nd Derivatives on Boundaries
David Scott
d.scott at ed.ac.uk
Thu Jan 10 09:44:35 CST 2013
All right, I'll say it differently. I wish to solve
div.grad phi = 0
with the boundary conditions that I have described.
On 10/01/2013 15:28, Jed Brown wrote:
> Second derivative is not a boundary condition for Poisson; that is the
> equation satisfied in the interior. Unless you are intentionally
> attempting to apply a certain kind of outflow boundary condition (i.e.,
> you're NOT solving Laplace) then there is a problem with your
> formulation. I suggest you revisit the continuum problem and establish
> that it is well-posed before concerning yourself with implementation
> details.
> On Thu, Jan 10, 2013 at 9:03 AM, David Scott <d.scott at ed.ac.uk
> <mailto:d.scott at ed.ac.uk>> wrote:
> Hello,
> I am solving Poisson's equation (actually Laplace's equation in this
> simple test case) on a 3D structured grid. The boundary condition in
> the first dimension is periodic. In the others there are Von Neumann
> conditions except for one surface where the second derivative is
> zero. I have specified DMDA_BOUNDARY_NONE in these two dimensions
> and deal with the boundary conditions by constructing an appropriate
> matrix. Here is an extract from the Fortran code:
> if (j==0) then
> ! Von Neumann boundary conditions on y=0 boundary.
> v(1) = 1
> col(MatStencil_i, 1) = i
> col(MatStencil_j, 1) = j
> col(MatStencil_k, 1) = k
> v(2) = -1
> col(MatStencil_i, 2) = i
> col(MatStencil_j, 2) = j+1
> col(MatStencil_k, 2) = k
> call MatSetValuesStencil(B, 1, row, 2, col, v,
> INSERT_VALUES, ierr)
> else if (j==maxl) then
> ! Boundary condition on y=maxl boundary.
> v(1) = 1
> v(2) = -2
> col(MatStencil_j, 2) = j-1
> v(3) = 1
> col(MatStencil_i, 3) = i
> col(MatStencil_j, 3) = j-2
> col(MatStencil_k, 3) = k
> call MatSetValuesStencil(B, 1, row, 3, col, v,
> else if (k==0) then
> Here the second clause deals with the second derivative on the boundary.
> In order for this code to work I have to set the stencil width to 2
> even though 'j-2' refers to an interior, non-halo
> point in the grid. This leads to larger halo swaps than would be
> required if a stencil width of 1 could be used.
> Is there a better way to encode the problem?
> David
> The University of Edinburgh is a charitable body, registered in
> Scotland, with registration number SC005336.
Dr. D. M. Scott
Applications Consultant
Edinburgh Parallel Computing Centre
Tel. 0131 650 5921
