[petsc-users] while solving the linear system with half billion unknowns on the super computer with 1020 cores, the preconditioner pcmg couldn't set up
Wed Jan 9 22:34:46 CST 2013
  The only thing specifically related to the number of unknowns that is not due to a bug in either your code or our code is if
1) the total problem size is greater than 2^31 - 1 (which it doesn't sound like in your case) or
2) the number of non zeros in a matrix on a single MPI process is more than 2^31 -1  (which could be if each process has a huge amount of memory)
  These limits are because by default PETSc uses 32 bit integers to hold indices and sizes. If you configure PETSc with --with-64-bit-indices then PETSc uses 64 bit integers to hold indices and sizes and you can solver any size problem.
   Barry
On Jan 9, 2013, at 12:45 PM, Fande Kong <fd.kong at siat.ac.cn> wrote:
> Hi all,
> I want to try to solve a problem with half billion unknowns with preconditioner pcmg (Of course, I have successfully provided the interpolation matrix and the coarse matrix).  When the size of the unknowns is 1e7 level, the solve work very well with 1020 cores on the super computer. But when the size of the unknowns increases to 1e8 level, the preconditioner setup stage break down. The following is my run script that I use to set the solver and the preconditioner.
>  -pc_type mg  -ksp_type fgmres  -pc_mg_levels 2 -pc_mg_cycle_type v -pc_mg_type multiplicative  -mg_levels_1_ksp_type richardson -mg_levels_1_ksp_max_it 1 -mg_levels_1_pc_type asm -mg_levels_1_sub_ksp_type preonly -mg_levels_1_sub_pc_type ilu -mg_levels_1_sub_pc_factor_levels 1 -mg_levels_1_sub_pc_factor_mat_ordering_type rcm -mg_coarse_ksp_type gmres -mg_coarse_ksp_rtol 0.1  -mg_coarse_ksp_max_it 2 -mg_coarse_pc_type asm -mg_coarse_sub_ksp_type preonly -mg_coarse_sub_pc_type ilu -mg_coarse_sub_pc_factor_levels 1 -mg_coarse_sub_pc_factor_mat_ordering_type rcm -ksp_view
> My question is weather the linear system with half billion unknowns is too big to solve. Or are there some bugs in preconditioner pcmg?
> Fande Kong
> ShenZhen Institutes of Advanced Technology
> Chinese Academy of Sciences
