[petsc-users] Example for MatMatMultSymbolic
Tue Jan 8 16:58:05 CST 2013
Typically you would use this, for which there are a few examples (at the
bottom of the page).
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatMatMult.html
If that doesn't fix your problem, please set up a test case or at least
give us verbose diagnostics.
On Tue, Jan 8, 2013 at 8:26 AM, Johannes Huber <johannes.huber at unibas.ch>wrote:
>  Hi,
> I have a valgrind "invalid read" in MatGetBrowsOfAoCols_MPIAIJ in the lines
>  rvalues  = gen_from->values; /* holds the length of receiving row */
>  svalues  = gen_to->values;   /* holds the length of sending row */
> (and others, but that are the first). This function is called indirectly
> via MatMatMultSymbolic.
> All invalid reads apear in MatGetBrowsOfAoCols_MPIAIJ.
> The calling sequence for the matrix factors are
>   MatCreate(PETSC_COMM_WORLD,A);
>   MatSetSizes(A,NumLocRows,NumLocCols,PETSC_DETERMINE,PETSC_DETERMINE);
>   MatSetType(A,MATMPIAIJ);
>   MatMPIAIJSetPreallocation(A,PETSC_NULL,nnz,PETSC_NULL,onz);
>   MatSetValues(...);
>   MatAssemblyBegin(...)
>   MatAssemblyEnd(...)
> and then a call to MatMatMultSymbolic.
> I want the result matrix to be created. In the documentation I see, that
> this happens, if I pass MAT_REUSE_MATRIX as scall, but how can I pass the
> value, I don't the parameter.
> Where can I find an example for MatMatMultSymbolic / MatMatMultNumeric?
> Thanks,
>     Hannes
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130108/2406bd4e/attachment.html>
