[petsc-users] PETSc and threads
Petar Petrovic ppetrovic573 at gmail.com
Fri Jan 4 13:34:36 CST 2013
MPI processes are fine, I didn't express myself clearly. Let me try with
another example.
Lets say I need to solve n linear systems Ax = b_i, i=1..n and I want to do
this in parallel. I would like to employ n processes to do this, so each
i-th process does A\b_i, and they all run in parallel. Something like:
for(i=0; i<n; i++)
   solve(Ax=b_i)
where I would like to run this for loop in parallel. Can I do this?
Let me just note that it doesn't necessarily need to be a A\b operation.
There are parts of my program that are embarrassingly parallel which I
would like to exploit.
On Fri, Jan 4, 2013 at 8:05 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> This is not supported due to logging/profiling/debugging features. Can you
> explain more about your problem and why you don't want to use MPI processes?
> On Fri, Jan 4, 2013 at 12:01 PM, Petar Petrovic <ppetrovic573 at gmail.com>wrote:
>> Hello,
>> I have read that PETSc isn't thread safe, however I am not sure I
>> understand in which way. What I would like to do is execute parts of my
>> code that make calls to PETSc routines in parallel, for example,
>> if I have matices A, B, C and D, is it possible to call MatMatMult(A,B)
>> on one thread and MatMatMult(C,D) on the other thread in parallel? Is there
>> an example which shows how to do something this, e.g. combine PETSc with
>> mine MPI calls or something similar?
>> Thank you very much for your help.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130104/91dfdb59/attachment.html>
