[petsc-users] csqrt
    Hui Zhang
    mike.hui.zhang at hotmail.com
    Thu Feb 28 16:08:56 CST 2013
On Feb 28, 2013, at 9:04 PM, Satish Balay wrote:
> On Thu, 28 Feb 2013, Barry Smith wrote:
>> On Feb 28, 2013, at 5:33 AM, Hui Zhang <mike.hui.zhang at hotmail.com> wrote:
>>> My cluster has an old version of glibc 2.3.3, which can not give usual principal value of square root.  For example, it gives square root of -i as the value with negative real part.
>>> I 'grep' in the source tree of petsc and found csqrt in many places.  Is this dangerous? Thank you!
>>   If you are using the default PETSc builds where it works with real numbers then it will have no effect on.
>>   If you are using PETSc with complex numbers you might consider changing the cluster software.
> presumably csqrt() is c99 - so c++ std:sqrt() is perhaps ok ok? [so one could use --with-clanguage=cxx]
Unfortunately, this does not work. Thanks any way!
> Satish
