[petsc-users] MATNEST with shell matrices
Amneet Bhalla
mail2amneet at gmail.com
Thu Feb 28 14:39:09 CST 2013
I am all for doing things the legal way :-)
Where should this routine be added and how should it look like for shell
vectors? I had assumed that
such changes should be done in user defined MatGetVecs routine. Clearly
this is not happening. Can you
comment on proper construction of duplicated Vecs which are needed by
Krylov solver of PETSc? The way I am
doing is :
a) Create a wrapper Vec (x), which holds SAMRAI vector.
b) Define a x->ops->duplicatevector for this wrapper vector.
c) Create a VecNest (X) of these wrapper Vecs.
d) Define MatGetVecs routine, which will duplicate X by the call
VecDuplicate(X,left/right)
On Thu, Feb 28, 2013 at 2:27 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> This is calling VecValidValues() checks for vec->ops->getarray. Since
> VecGetArray_Nest() is implemented, it calls the routine. I'm inclined to
> add a vec->ops->validvalues() and _not_ try to hack it in terms of
> VecGetArray().
Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130228/4d708842/attachment.html>
