[petsc-users] Scale the diagonal entries of a Mat
Sat Feb 23 07:32:36 CST 2013
You should really use MatSetValuesLocal with ADD_VALUES *before* assembling.
On Feb 23, 2013 7:28 AM, "Hui Zhang" <mike.hui.zhang at hotmail.com> wrote:
> On Feb 23, 2013, at 1:37 PM, Matthew Knepley wrote:
> > On Sat, Feb 23, 2013 at 7:35 AM, Hui Zhang <mike.hui.zhang at hotmail.com>
> wrote:
> > On Feb 23, 2013, at 1:32 PM, Matthew Knepley wrote:
> > > On Sat, Feb 23, 2013 at 7:29 AM, Hui Zhang <mike.hui.zhang at hotmail.com>
> wrote:
> > > I want to implement diagonal penalty method for enforcing the
> Dirichlet boundary conditions.  That is, the diagonal entries corresponding
> to Dirichlet boundary are going to be scaled by a large number.
> > > What is the easiest way to do this?  Thanks!
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatDiagonalScale.html
> > But it seems not what I want.  That routine scales all the entries of a
> mat.  I want to scale only the diagonal entries.
> > Then use
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatDiagonalSet.html
> I want to do the following on an already assembled matrix (FINAL_ASSEMBLY).
> MatGetLocalSubMatrix .. to get 'submat',
> MatGetDiagonal .. to get diagonal vector 'diag',
> VecScale .. to scale 'diag'
> MatDiagonalSet .. to set scaled 'diag' to 'submat'
> MatRestoreLocalSubMatrix .. to restore 'submat'
> After the above process, do I need MatAssemblyBegin/End again?  I do not
> know why the penalty method is bad.  Maybe because the bad conditioning?  I
> just want to try out and compare with MatZeroRowsColumns (lift and remove)
> method.
> > As Jed says, you really really do not want to do this.
> >   Matt
> > >   Matt
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130223/dba9508d/attachment.html>
