[petsc-users] PETSc DAE solver
Jin, Shuangshuang Shuangshuang.Jin at pnnl.gov
Wed Feb 20 12:39:02 CST 2013
Shri, thank you! That's very helpful information. I'm going to obtain the development version of PETSc now.
Shuangshuang
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Shri
Sent: Wednesday, February 20, 2013 10:34 AM
To: PETSc users list
Subject: Re: [petsc-users] PETSc DAE solver
Jin,
   If you are working on integrating power grid DAE equations  then you should use petsc-dev instead as we've added an example for it. petsc-dev/src/ts/examples/tutorials/power_grid/stabiltiy_9bus/ex9bus.c. There are other examples in the power_grid directory.
Shri
On Feb 20, 2013, at 12:19 PM, Jin, Shuangshuang wrote:
Hi, I'm trying to use PETSc to solve a set of first-order differential and algebraic equations such as:
x' =  f(x,y)
0 = g(x,y)
The resources I can find online so far are
 1.  PETSc Manual: Chapter 6 TS: Scalable ODE and DAE Solvers
 2.  petsc-3.3-p6/src/ts/examples/tutorials
which still seems  vague to me at this moment.
Can anyone tell me if there's any more specific references I can refer to as a starting point to tackle this problem?
Shuangshuang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130220/0f5ca0b0/attachment.html>
