[petsc-users] Convergence is different with different processors
w_ang_temp w_ang_temp at 163.com
Sat Feb 16 12:21:29 CST 2013
Hello, Barry
    Is it true that BJacobi preconditioner is only one type of ASM preconditioner(overlap=0), it is only one part of ASM?
    I find that sometimes the two have the same results while sometimes they are not. Is the reason that PETSc can
internally get the better parameter when using ASM, and sometimes it use overlap=0 then ASM and BJacobi have the same
results.
    If it is true, ASM is always better than BJacobi?
Thanks.                   Jim
At 2013-02-17 01:57:46,"Barry Smith" <bsmith at mcs.anl.gov> wrote:
>  This is completely possible. The convergence of iterative methods is a complicated business. Even something seemingly simple like block Jacobi whose conver> gence depends not only on the number of blocks, but the "shapes" of the blocks and what part of the matrix is "discarded" in the preconditioner depending on the > number and "shape" of the blocks. Decomposing the domain into 4 and 8 pieces results in different "shapes" of the blocks and different parts of the matrix being "> discarded" in the preconditioner.
>   Barry
>On Feb 16, 2013, at 11:36 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>> I use the two commands in the same project. The first is divergent while the second is convergent.
>> nohup mpiexec -n 4 ./ex4f -ksp_type bcgs -pc_type bjacobi -ksp_rtol 1.0e-5 -ksp_converged_reason >out.txt &
>> nohup mpiexec -n 8 ./ex4f -ksp_type bcgs -pc_type bjacobi -ksp_rtol 1.0e-5 -ksp_converged_reason >out.txt &
>> So what is the reason?
>> Thanks.                    Jim
>> >> 2013-02-07 13:16:51,"Matthew Knepley" <knepley at gmail.com> 写道:
>> >> On Thu, Feb 7, 2013 at 12:11 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>> >> Hello,
>> >>     I use the same project, but I find that when different number of processors is choosed,
>> >> the convergence is different. For example, when the processors are 4, it is divergent; when
>> >> the processors are 8, it is convergent.
>> >It is likely that your preconditioner changed.
>>   > Matt
>> >>     Thanks.
>> >>                                    Jim.
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130217/0087b79a/attachment.html>
