[petsc-users] Convergence is different with different processors
w_ang_temp w_ang_temp at 163.com
Sat Feb 16 11:36:35 CST 2013
I use the two commands in the same project. The first is divergent while the second is convergent.
nohup mpiexec -n 4 ./ex4f -ksp_type bcgs -pc_type bjacobi -ksp_rtol 1.0e-5 -ksp_converged_reason >out.txt &
nohup mpiexec -n 8 ./ex4f -ksp_type bcgs -pc_type bjacobi -ksp_rtol 1.0e-5 -ksp_converged_reason >out.txt &
So what is the reason?
Thanks.                    Jim
>> 2013-02-07 13:16:51,"Matthew Knepley" <knepley at gmail.com> 写道:
>> On Thu, Feb 7, 2013 at 12:11 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>> Hello,
>>     I use the same project, but I find that when different number of processors is choosed,
>> the convergence is different. For example, when the processors are 4, it is divergent; when
>> the processors are 8, it is convergent.
>It is likely that your preconditioner changed.
  > Matt
>>     Thanks.
>>                                    Jim.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130217/671a6313/attachment.html>
