[petsc-users] Viewing local matrices
Thu Feb 14 13:00:16 CST 2013
On Feb 14, 2013, at 12:32 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Feb 14, 2013 at 1:22 PM, Chekuri Choudary <cchoudary at rnet-tech.com> wrote:
> How can I view the local matrices on each processor. I am trying to understand how a DMDA matrix is being distributed among multiple processes.
   Consider 2d: the domain is split into rectangular subregions (depending on how many processors there are and how many grid points in the x and y directions).
Each process is assigned one of these subregions. For any run you can use DMView(da,PETSC_VIEWER_STDOUT_(comm)); to see the decomposition.
Now as always with PETSc vectors all the vector entries on the first process are numbered first, followed by the vector entries on the second, third etc. Similarly for matrices the rows associated with the vector entries on the first process are numbered first, then the rows associated with vector entries on the second etc.  Thus the entries in the vector are not in the "natural ordering for the entire domain". But VecView() and MatView() for DMDA automatically reorder so that when you see the vectors and matrices they are in the natural ordering.
  You are over thinking things if you want to see the matrix in the "non-natural ordering", there is no reason to worry about that. Just use MatSetValuesLocal() or MatSetValuesStencil() to enter entries and the fact that PETSc internally uses this other non-natural ordering is not important in using it.
   What particular issue are you trying to resolve by "viewing the local matrices on each process"?
   Barry
> Rows are contiguous so viewing the global matrix shows you the local pieces.
>    Matt
> Thanks
> Chekuri
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
