[petsc-users] [Libmesh-users] Preconditioning of a Stokes	problem
    Dmitry Karpeev
    karpeev at mcs.anl.gov
    Mon Feb  4 12:30:39 CST 2013
Francesco,
Are you using any pressure stabilization scheme? If not, the 11-block in
your Jacobian
A = [A00 A01; A10 A11] would typically be zero, and preconditioning it with
jacobi wouldn't really work.
If A11 = 0, you ought to use the fieldsplit of type Schur, for example
(assuming petsc-3.3; prior versions use slightly different option names):
-pc_fieldsplit_type schur -pc_fieldsplit_schur_fact_type full
The question is then how you want to solve the Schur complement system.
Since the A11 block for you is zero, the easiest choice is to use S as the
preconditioning matrix:
-pc_fieldsplit_schur_precondition self
Preconditioning options for the Schur solver have prefix -fieldsplit_1_.
Since for Stokes the Schur complement is spectrally equivalent to the
pressure mass matrix, you can
hope that an unpreconditioned GMRES (default when using
-pc_fieldsplit_schur_precondition self) will solve it.
A better choice might be to use the Least Squares Commutator preconditioner
-fieldsplit_1_pc_type lsc
See
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCLSC.html
and note the relevant references at the bottom of that manual page.
You might also find this useful:
http://www.icfd.rdg.ac.uk/ICFD25/Talks/AWathen.pdf
PCLSC preconditions S = A10 inv(A00) A01 with  inv(A10A01) A10 A00 A01
inv(A10A01)
The "Laplacian" (a true Laplacian in the case of incompressible Stokes) can
be preconditioned
using AMG:
-fieldsplit_1_lsc_pc_type ml
(assuming you have ML built, e.g., with --download-ml)
or
-fieldsplit_1_lsc_pc_type gamg
with some appropriate choice of gamg options:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMG.html
To start with I would use -pc_fieldsplit_type schur
-pc_fieldsplit_schur_fact_type full -pc_fieldsplit_schur_precondition self
-fieldsplit_1_pc_type lsc -fieldsplit_1_lsc_pc_type ml
gamg may also be very good in place of ml, but will require more option
setting.
You might find src/ksp/ksp/examples/tutorials/ex42.c and ex43.c useful,
albeit, possibly, a bit heavyweight for your needs.
A few more comments below:
On Mon, Feb 4, 2013 at 10:20 AM, John Peterson <jwpeterson at gmail.com> wrote:
> On Thu, Dec 27, 2012 at 4:31 AM, Francesco Ballarin
> <francesco.ballarin at mail.polimi.it> wrote:
> > Dear libMesh users,
> > I am trying to solve a Stokes problem in a 3D domain, but I am currently
> > struggling with the choice of the preconditioner.
> > I have slightly modified systems_of_equations_ex1 to accommodate for the
> > third velocity component and boundary conditions of the problem at hand
> > (Dirichlet BCs on the inlet on the walls, enforced using a
> > DirichletBoundary object, and homogeneous Neumann BC on the outflow)
> > I am trying to use PETSc block preconditioners as shown, e.g., in
> > http://acts.nersc.gov/events/Workshop2012/slides/PETSc.pdf
> > section 4. I have tried most of the preconditioners discussed during the
> > talk, but I am not satisfied because I get either PETSc errors or a
> > performance that I hope can be increased.
> > For example, with the following options:
> >   PetscOptionsSetValue("-ksp_type", "gmres");
> > PetscOptionsSetValue("-ksp_right_pc", PETSC_NULL);
> >  PetscOptionsSetValue("-pc_type", "fieldsplit");
> > PetscOptionsSetValue("-pc_fieldsplit_detect_saddle_point", PETSC_NULL);
> >  PetscOptionsSetValue("-pc_fieldsplit_type", "multiplicative");
> > PetscOptionsSetValue("-fieldsplit_0_ksp_type", "preonly");
> >  PetscOptionsSetValue("-fieldsplit_0_pc_type", "ml");
> > PetscOptionsSetValue("-fieldsplit_1_ksp_type", "preonly");
> >  PetscOptionsSetValue("-fieldsplit_1_pc_type", "jacobi");
You do not need to set options to PETSC_NULL, if you do not intend to use
them.
Also, how are you forming the splits?
-pc_fieldsplit_detect_saddle_point is actually rather useful here.
Further, there are programmatic ways to set most of these options, for
example:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetType.html
Even so, we typically recommend setting these on the command line whenever
possible:
this way you do not hardwire your solver choices and can quickly experiment
with different
solvers from the command-line without recompiling your code.
> > I obtain a reasonable solution but after thousands of gmres iterations.
> Is
> > there any way to improve that?
> > Or, if I try to embed the previous block preconditioner in mg:
> > PetscOptionsSetValue("-pc_type", "mg");
> >  PetscOptionsSetValue("-pc_mg_levels", "5");
> > PetscOptionsSetValue("-pc_mg_galerkin", PETSC_NULL);
> > PetscOptionsSetValue("-mg_levels_pc_type", "fieldsplit");
> >  PetscOptionsSetValue("-mg_levels_pc_fieldsplit_detect_saddle_point",
> > PETSC_NULL);
> > PetscOptionsSetValue("-mg_levels_pc_fieldsplit_type", "multiplicative");
> >  PetscOptionsSetValue("-mg_levels_fieldsplit_0_ksp_type", "preonly");
> > PetscOptionsSetValue("-mg_levels_fieldsplit_0_pc_type", "gamg");
> >  PetscOptionsSetValue("-mg_levels_fieldsplit_1_ksp_type", "preonly");
> > PetscOptionsSetValue("-mg_levels_fieldsplit_1_pc_type", "jacobi");
> > I get the following error:
Always send the full stack trace, when reporting errors.
Finally, in the future you might want to post these questions to
petsc-users at mcs.anl.gov
Dmitry.
> > PETSC ERROR: Null argument, when expecting valid pointer!
> > PETSC ERROR: Null Object: Parameter # 2!
> > PETSC ERROR: MatPtAP() line 8237 in
> petsc-3.3-p4/src/mat/interface/matrix.c
> > Do you have any suggestion? What are you currently using as
> preconditioner
> > for saddle point problems?
> Apologies, it appears that this email fell through the cracks
> somewhere back around the holidays.
> Did you ever find a satisfactory answer to your question?
> Petsc developers may occasionally read this list, but for questions
> that are this advanced you would probably have better luck mailing the
> petsc developers list directly.
> And of course if you do find a good block preconditioning strategy for
> systems_of_equations_ex1, please feel free to report it here!
> John
> Everyone hates slow websites. So do we.
> Make your web apps faster with AppDynamics
> Download AppDynamics Lite for free today:
> http://p.sf.net/sfu/appdyn_d2d_jan
> Libmesh-users mailing list
> Libmesh-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/libmesh-users
Dmitry Karpeev, Ph.D.
Assistant Computational Mathematician
Mathematics and Computer Science
Argonne National Laboratory
Argonne, Illinois, USA
and
Fellow
Computation Institute
University of Chicago
5735 S. Ellis Avenue
Chicago, IL 60637
Phone: 630-252-1229
 Fax:   630-252-5986
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130204/b985b326/attachment.html>
