[petsc-users] GPU local direct solve of penta-diagonal
Jed Brown
jedbrown at mcs.anl.gov
Fri Dec 13 01:38:13 CST 2013
Paul Mullowney <paulmullowney at gmail.com> writes:
> Provided you have a good parallel sparse direct solve for a single SM, you
> could unleash 32 direct solves (or perhaps 16) which run concurrently on
> the K20x. One only needs to set an environment variable to use Hypre Q
Where is the "good" sparse direct solver that uses one SM and solves a
problem with a few thousand degrees of freedom?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131212/73696b70/attachment.pgp>
