[petsc-users] GAMG and linear elasticity
    Tabrez Ali
    stali at geology.wisc.edu
    Tue Aug 27 17:22:03 CDT 2013
I had missed PCSetCoordinates in ex56.
So is there a correspondence b/w the coordinates [0.x 0.y 0.z 1.x 1.y
1.z ...] passed to PCSetCoordinates/MatNullSpaceCreateRigidBody and
the solution vector [0.ux 0.uy 0.uz ...]? What happens when I am
solving the poroelasticity problem where there is an additional
pressure field associate with each node?
Tabrez
On Aug 27, 2013, at 3:15 PM, Jed Brown wrote:
> Tabrez Ali <stali at geology.wisc.edu> writes:
>> Hello
>> What is the proper way to use GAMG on a vanilla 3D linear elasticity
>> problem. Should I use
>> -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1
> Yeah, and only the first of these is needed because the others are
> default with -pc_type gamg.
>> -pc_type fieldsplit -pc_fieldsplit_block_size 3 -fieldsplit_pc_type
>> gamg
>> -fieldsplit_pc_gamg_type agg -fieldsplit_pc_gamg_agg_nsmooths 1
>> Do these options even make sense? With the second set of options
>> the %
>> increase in number of iterations with increasing problem size is
>> lower
>> than the first but not optimal.
> And it's probably more expensive because it has to do inner solves.
> Also, if you have less compressible regions, it will get much worse.
>> Also, ksp/ksp/examples/ex56 performs much better in that the number
>> of
>> iterations remain more or less constant unlike what I see with my own
>> problem. What am I doing wrong?
> You probably forgot to set the near null space.  You can use
> MatSetNearNullSpace (and maybe MatNullSpaceCreateRigidBody) or the
> more
> hacky (IMO) PCSetCoordinates.  It's important to have translational
> *and* rotational modes in the near null space that GAMG uses to
> build a
> coarse space.
