[petsc-users] Should I synchronize processes explicitly, for instance using MPI_Barrier?
Cong Li
solvercorleone at gmail.com
Fri Aug 16 06:31:58 CDT 2013
Hi, Matthew
Thank you very much for the answer.
And I met a new problem.
When there some PetscScalar type data operations before the VecWAXPY call,
for example
PetscScalar, a,b, c;
c=a+b;
ierr = VecWAXPY(r, c, Ax, b);CHKERRQ(ierr);
, should I add MPI_Barrier call right before VecWAXPY call ?
Best regards
Cong
On Fri, Aug 16, 2013 at 7:56 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Aug 16, 2013 at 2:11 AM, Cong Li <solvercorleone at gmail.com> wrote:
>> Hi
>> I am a rookie to PETSc, and I am wondering about whether I should call
>> MPI_Barrier to explicitly synchronize processes between PETSc calls.
>> For example, a piece of code like below
>> ierr = MatMult(A,x,Ax); CHKERRQ(ierr);
>> ierr = VecWAXPY(r, neg_one, Ax, b);CHKERRQ(ierr);
>> Should I add MPI_Barrier inbetween MatMult call and VecWAXPY call ?
> No
> Matt
>> My guess is that it is unnecessary. However, I am not so confident in
>> this guess, for I don't have much experience on using PETSc.
>> Thanks in advance.
>> Cong Li
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130816/a6e59ab0/attachment.html>
