[petsc-users] Plex Submesh
Dharmendar Reddy dharmareddy84 at gmail.com
Tue Apr 30 02:57:08 CDT 2013
Hello,
         I have a doubt about how the node ordering in plex submesh is
created.
I create a oneD mesh along y-direction from a two dimensional square mesh
in x-y direction.  In the original mesh the nodes are indexed such that the
count increase in y-direction first and then in x-direction.
Consider a 5 by 5 square mesh
Now the oneD subdm  has 5 nodes and 4 cells
if the coordinates of the nodes is [0,1.0,2.0,3.0,4.0]   in x and y drection
I see that  cells in the subdm for x=1.0 have support:
Vertex id here is the numbering with respect to subdm.
cellId:     vertexId       ExpectedVertexId (or atleast i want this also
this will be the
        case for
x = 0.0)
 0            5    4            4  5
 1            6    5            5  6
 2            7    6            6  7
 3            8    7            7   8
 Of course this is consistent with the node ordering in original dm but i i
use the coordinates of the nodes i get detJacobain negative.
I am not sure if this make sense ....
Should not (or can ) the nodes in the subdm be reoriented such that they
all have positive orientation ?
Since i am creating the subdm using indexset of a select points in original
dm, i can see that the connectivity is preserved.
Should i create a new dm using DMcreatefromCellList after fixing the
orientations ? but then i need maps from this dm to orignal dm to access
the dof values.
Thanks
Reddy
Dharmendar Reddy Palle
Graduate Student
Microelectronics Research center,
University of Texas at Austin,
10100 Burnet Road, Bldg. 160
MER 2.608F, TX 78758-4445
e-mail: dharmareddy84 at gmail.com
Phone: +1-512-350-9082
United States of America.
Homepage: https://webspace.utexas.edu/~dpr342
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130430/d9345f50/attachment.html>
