[petsc-users] Help with ML/BoomerAMG
Gaetan Kenway gaetank at gmail.com
Mon Apr 29 09:41:32 CDT 2013
It is an SA turbulence model and the discrete adjoint computed exactly with
AD. Certainly the grids are highly stretched in the BL since the grids are
resolving the viscous sublayer (y+ < 1) and the  Reynolds numbers are on
the order of  10's of millions. I tend  only to see this behaviour at
higher mach numbers when stronger shocks start to appear.  For example, the
adjoint  system may solve  fine at M=0.80, and fail to converge at M=0.85.
 For these RANS cases, the non-linear  solution  is solved using only RK
with multigrid.
It is entirely possible a different preconditioner may not help at all, but
there's not much else you can do.
Gaetan
On Mon, Apr 29, 2013 at 10:31 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Gaetan Kenway <gaetank at gmail.com> writes:
> > For the forward solve I use ASM+ILU in the same manner as for the adjoint
> > problem.
> > The  ASM not a bottleneck  per se. Typically we see the  adjoint problem
> > taking the same amount of time as the non-linear problem for well-behaved
> > flows, and the adjoint is shorter for  less well-behaved flows.
> Sounds reasonable.
> > The real problem I am having is for certain RANS cases, the
> > frozen turbulence adjoint is extremely difficult to solve --- requiring
> >  GMRES subspace sizes on the order of 400-500 to converge.
> Hmm, which turbulence model are you using?  Is it related to stretched
> grids?  Continuous or discrete adjoint?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130429/ded86ace/attachment.html>
