[petsc-users] Help with ML/BoomerAMG
Gaetan Kenway gaetank at gmail.com
Sun Apr 28 18:01:29 CDT 2013
Hello
I am the process of trying out some of the multigrid functionality in PETSc
and not having much luck. The simple system I am trying to solve is adjoint
system of equations resulting from the finite volume discretization of the
Euler equation on a 147,456 cell mesh resulting in a linear system of
equations of size 5*147,456=737280. All of the test are done on a single
processor and use petsc-3.2-p7. My current technique for solving this is to
use following options:
-matload_block_size 5 -mat_type seqbaij -ksp_type gmres -ksp_max_it 100
-ksp_gmres_restart 50  -ksp_monitor -pc_type asm   -pc_asm_overlap 1
-sub_pc_factor_mat_ordering_type rcm -sub_pc_factor_levels 1
Which results in ~1e-6 convergence in ~50 iterations.  Next I naively tried
the following options:
-mat_type seqaij -ksp_type gmres -ksp_max_it 100 -ksp_gmres_restart 50
-ksp_monitor -ksp_view -pc_type ml
The result of the ksp_monitor and ksp_view is:
  0 KSP Residual norm 7.366926114851e+70
  1 KSP Residual norm 1.744597669120e+61
KSP Object: 1 MPI processes
  type: gmres
    GMRES: restart=50, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=100, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: ml
    MG: type is MULTIPLICATIVE, levels=5 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_coarse_)     1 MPI processes
      type: preonly
      maximum iterations=1, initial guess is zero
      using NONE norm type for convergence test
    PC Object:    (mg_coarse_)     1 MPI processes
      type: lu
        LU: out-of-place factorization
        tolerance for zero pivot 1e-12
        matrix ordering: nd
        factor fill ratio given 5, needed 1
          Factored matrix follows:
            Matrix Object:             1 MPI processes
              type: seqaij
              rows=1, cols=1
              package used to perform factorization: petsc
              total: nonzeros=1, allocated nonzeros=1
              total number of mallocs used during MatSetValues calls =0
                not using I-node routines
      linear system matrix = precond matrix:
        type: seqaij
        rows=1, cols=1
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object:    (mg_levels_1_)     1 MPI processes
      type: richardson
        Richardson: damping factor=1
      using nonzero initial guess
    PC Object:    (mg_levels_1_)     1 MPI processes
      type: sor
        SOR: type = local_symmetric, iterations = 1, local iterations = 1,
omega = 1
        type: seqaij
        rows=2, cols=2
        total: nonzeros=4, allocated nonzeros=4
          using I-node routines: found 1 nodes, limit used is 5
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (mg_levels_2_)     1 MPI processes
      type: richardson
    PC Object:    (mg_levels_2_)     1 MPI processes
      type: sor
omega = 1
        type: seqaij
        rows=93, cols=93
        total: nonzeros=3861, allocated nonzeros=3861
  Down solver (pre-smoother) on level 3 -------------------------------
    KSP Object:    (mg_levels_3_)     1 MPI processes
      type: richardson
    PC Object:    (mg_levels_3_)     1 MPI processes
      type: sor
omega = 1
        type: seqaij
        rows=8303, cols=8303
        total: nonzeros=697606, allocated nonzeros=697606
  Down solver (pre-smoother) on level 4 -------------------------------
    KSP Object:    (mg_levels_4_)     1 MPI processes
      type: richardson
    PC Object:    (mg_levels_4_)     1 MPI processes
      type: sor
omega = 1
        type: seqaij
        rows=737280, cols=737280
        total: nonzeros=46288425, allocated nonzeros=46288425
          using I-node routines: found 147456 nodes, limit used is 5
    type: seqaij
Time:   11.8599750995636
 Actual res norm:  0.132693075876745
It stopped after the second iteration because it "converged" over 6 orders
of magnitude. Of course, it didn't actually converge and the actual
residual remained unchanged. Given that that the coarse solver is LU and
all the smoothers are KSPRichardson with 1 iteration and SOR smoothing, I
should be able to use GMRES.  I also tried it with
-ksp_type fgrmes  and all the other options the same.
This time, it doesn't blowup, but also doesn't make significant progress.
The actual residual at end of 100 iterations is larger than the real
initial residual. (The ksp_view for this is identical except for the change
is ksp type to fgmres and the use of right preconditioning.
 0 KSP Residual norm 1.326930758772e-01
 10 KSP Residual norm 1.326906693969e-01
 20 KSP Residual norm 1.326879007861e-01
 30 KSP Residual norm 1.326851758083e-01
 40 KSP Residual norm 1.326824509983e-01
 50 KSP Residual norm 1.333174206652e-01
 60 KSP Residual norm 1.279860083890e-01
 70 KSP Residual norm 1.227523658429e-01
 80 KSP Residual norm 1.181123717224e-01
 90 KSP Residual norm 1.139616660987e-01
100 KSP Residual norm 1.102198901480e-01
 Time:   67.6706080436707
 Actual res norm:  0.443508987516716
I then started trying some of the ML options. Specifically,
-pc_mg_smoothup 3
-pc_mg_smoothdown 3
Now it returns a floating point exception:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Floating point exception!
[0]PETSC ERROR: Infinite or not-a-number generated in norm!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 7, Thu Mar 15 09:30:51
CDT 2012
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./main on a real-opt named mica by kenway Sun Apr 28
18:32:22 2013
[0]PETSC ERROR: Libraries linked from
/home/kenway/Downloads/petsc-3.2-p7/real-opt/lib
[0]PETSC ERROR: Configure run at Sun Apr 28 15:16:05 2013
[0]PETSC ERROR: Configure options --with-shared-libraries
--download-superlu_dist=yes --download-parmetis=yes
--with-fortran-interfaces=1 --with-debuggig=no -with-scalar-type=real
--PETSC_ARCH=real-opt --download-hypre=yes --download-spai=yes
--download-sundials=yes --download-ml=yes
[0]PETSC ERROR:
[0]PETSC ERROR: VecNorm() line 167 in src/vec/vec/interface/rvector.c
[0]PETSC ERROR: VecNormalize() line 261 in src/vec/vec/interface/rvector.c
[0]PETSC ERROR: GMREScycle() line 128 in src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: KSPSolve_GMRES() line 231 in src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: KSPSolve() line 423 in src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: PCMGMCycle_Private() line 55 in src/ksp/pc/impls/mg/mg.c
[0]PETSC ERROR: PCMGMCycle_Private() line 49 in src/ksp/pc/impls/mg/mg.c
[0]PETSC ERROR: PCApply_MG() line 320 in src/ksp/pc/impls/mg/mg.c
[0]PETSC ERROR: PCApply() line 383 in src/ksp/pc/interface/precon.c
[0]PETSC ERROR: FGMREScycle() line 174 in
src/ksp/ksp/impls/gmres/fgmres/fgmres.c
[0]PETSC ERROR: KSPSolve_FGMRES() line 299 in
 Time:   20.1171851158142
 Actual res norm:  0.132693075877161
So I tried running with
-pc_mg_smoothup 1
-pc_mg_smoothdown 1
This runs, but somehow does not result in the same sequence of KSP objects
on the various levels.
 10 KSP Residual norm 1.310779571550e-01
 20 KSP Residual norm 1.290623886203e-01
 30 KSP Residual norm 1.271370286802e-01
 40 KSP Residual norm 1.252953431171e-01
 50 KSP Residual norm 3.224565651498e-01
 60 KSP Residual norm 2.974317106914e-01
 70 KSP Residual norm 2.708573182063e-01
 80 KSP Residual norm 2.503317725548e-01
 90 KSP Residual norm 2.338612668565e-01
100 KSP Residual norm 2.202653375200e-01
  type: fgmres
  using UNPRECONDITIONED norm type for convergence test
  type: ml
      type: preonly
      type: lu
        matrix ordering: nd
              type: seqaij
              rows=1, cols=1
        type: seqaij
        rows=1, cols=1
      type: richardson
      type: sor
omega = 1
        type: seqaij
        rows=2, cols=2
  Up solver (post-smoother) on level 1 -------------------------------
      type: gmres
        GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
      type: ilu
        ILU: out-of-place factorization
        0 levels of fill
        using diagonal shift to prevent zero pivot
        matrix ordering: natural
        factor fill ratio given 1, needed 1
              type: seqaij
              rows=2, cols=2
        type: seqaij
        rows=2, cols=2
      type: richardson
      type: sor
omega = 1
        type: seqaij
        rows=93, cols=93
  Up solver (post-smoother) on level 2 -------------------------------
      type: gmres
      type: ilu
        0 levels of fill
              type: seqaij
              rows=93, cols=93
        type: seqaij
        rows=93, cols=93
      type: richardson
      type: sor
omega = 1
        type: seqaij
  Up solver (post-smoother) on level 3 -------------------------------
      type: gmres
      type: ilu
        0 levels of fill
              type: seqaij
        type: seqaij
      type: richardson
      type: sor
omega = 1
        type: seqaij
  Up solver (post-smoother) on level 4 -------------------------------
      type: gmres
      type: ilu
        0 levels of fill
              type: seqaij
        type: seqaij
    type: seqaij
 Time:   118.043510913849
 Actual res norm:   1.11054776641920
Now, the Down Solver is still KSPRichardson, but the UP solvers have turned
into a default GMRES, ILU solver. In either case, this didn't help the
convergence, and the final residual is larger than then initial.
I have also experimented with BoomerAMG, and have run into similar
problems; all of the various options result in a preconditioner that is not
significantly better tan not using any preconditioner at all.
Any suggestions would be greatly appreciated.
Thank you,
Gaetan Kenway
The compete source code listing is below:
program main
  ! Test different petsc solution techniques
  implicit none
#include "include/finclude/petsc.h"
  KSP ksp
  Vec RHS, x, res
  Mat A
  PetscViewer fd
  integer :: ierr, rank
  real*8 :: timeA, timeB,err_nrm
  ! Initialize PETSc
  call PetscInitialize('petsc_options', ierr)
  call mpi_comm_rank(PETSC_COMM_WORLD, rank, ierr)
  ! Load matrix
  call PetscViewerBinaryOpen(PETSC_COMM_WORLD,"drdw.bin", FILE_MODE_READ,
fd, ierr)
  call MatCreate(PETSC_COMM_WORLD, A, ierr)
  call MatSetFromOptions(A, ierr)
  call MatLoad(A, fd, ierr)
  call PetscViewerDestroy(fd, ierr)
  ! Create vector
  call MatGetVecs(A, RHS, x, ierr)
  call vecduplicate(x, res, ierr)
  ! Load RHS
  call PetscViewerBinaryOpen(PETSC_COMM_WORLD, "didw.bin", FILE_MODE_READ,
fd, ierr)
  call VecSetFromOptions(RHS, ierr)
  call VecLoad(RHS, fd, ierr)
  ! Create KSP object
  call KSPCreate(PEtSC_COMM_WORLD, ksp, ierr)
  call KSPsetFromOptions(ksp, ierr)
  call KSPSetOperators(ksp, A, A, SAME_NONZERO_PATTERN, ierr)
  ! Solve system
  timeA = mpi_wtime()
  call KSPSolve(ksp, RHS, x, ierr)
  timeB = mpi_wtime()
  if (rank == 0) then
     print *,'Time:',timeB-timeA
  end if
  ! Check actual error
  call MatMult(A, x, res, ierr)
  call VecNorm(res, NORM_2, err_nrm, ierr)
  call VecAxPy(res, -1.0_8, RHS, ierr)
  if (rank == 0) then
     print *,'Actual res norm:',err_nrm
  end if
  ! Destroy
  call KSPDestroy(ksp, ierr)
  call MatDestroy(A, ierr)
  call VecDestroy(RHS, ierr)
  call VecDestroy(x, ierr)
  call VecDestroy(res, ierr)
  ! Finalize
  call PETSCFinalize(ierr)
end program main
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130428/50a3fe14/attachment-0001.html>
