[petsc-users] command line handling in PETSC 3.2, a simple fix for Wheezy?
Alexei Matveev alexei.matveev+petsc at gmail.com
Fri Apr 26 07:17:03 CDT 2013
Dear List,
While porting an application to the upcoming Debian Wheeze
we noted a misbehaviour in command line parsing by PETSC 3.2.
It looks like if a "--key value" pair is following a "--flag-with-no-value"
option
at the leading position, the key-value pair is being ignored. See minimal
example below.
Is this something known? Is there a simple fix that had a chance
to convince Debian maintainers to apply it before 7.0 or even
7.0.1?
Alexei, Bo
$ cat options.c
#include "petsc.h"
int main( int argc, char *argv[] )
    int val1 = 1;
    int val2 = 2;
    PetscBool test;
    PetscErrorCode ierr;
    PetscInitialize( &argc, &argv, 0, 0);
    ierr = PetscOptionsHasName (PETSC_NULL, "--test", &test);
    if (test)
        PetscPrintf (PETSC_COMM_WORLD, "with --test option\n");
    else
        PetscPrintf (PETSC_COMM_WORLD, "without --test option \n");
    ierr = PetscOptionsGetInt (PETSC_NULL, "--op1", &val1, &test);
    ierr = PetscOptionsGetInt (PETSC_NULL, "--op2", &val2, &test);
    PetscPrintf (PETSC_COMM_WORLD, "op1: %d\n", val1);
    PetscPrintf (PETSC_COMM_WORLD, "op2: %d\n", val2);
    PetscFinalize();
    return 0;
When executing on neh13, "--opt1" couldn't get its value from command line
when the no-value option "--test" appears before it:
lib at neh13:~/petsc/options$ ./test --test --op1 23 --op2 45
with --test option
op1: 1
op2: 45
lib at neh13:~/petsc/options$ ./test --op1 23 --op2 45
op1: 23
op2: 45
lib at neh13:~/petsc/options$ ./test --op1 23 --op2 45 --test
with --test option
op1: 23
op2: 45
I also test it on quad4 and on my local cluster with the latest version of
Petsc(3.3), this bug doesn't appear:
lib at crc3:~/petsc/options$ ./test --test --op1 23 --op2 45
with --test option
op1: 23
op2: 45
Looks it only exists in Petsc-3.2 :(
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130426/d61f75e2/attachment.html>
