[petsc-users] macport and petsc
Satish Balay
balay at mcs.anl.gov
Wed Apr 24 22:29:09 CDT 2013
On Wed, 24 Apr 2013, Barry Smith wrote:
> On Apr 24, 2013, at 10:00 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > compressed logs to petsc-users/petsc-dev is acceptable now.
> > [not sure if autocompression of attachments can be setup with mailmain
> > mailing lists]
> > macports has some conflicts with the default blas/lapack - so its best
> > to avoid it. [you can use --download-openmpi to get non-macports mpi]
> Satish,
> We should fix the PETSc BLAS/LAPACK configuration (BuildSystem) to not "have conflicts with macports blas/lapack" by, for example, to use the Apple BLAS/LAPACK if the macports one fail. That is, we shouldn't tell people not to use macports, we should have a configuration system robust enough to handle macports problems. Is this a problem we can reproduce? and hence debug? and hence fix?
I don't remember the exact issue. [a configure.log for this failure
can perhaps refresh our memories]
One way a conflicts creep in is - with non-blas-lapack packages that a
user might specify from macports.
For ex: configure check for blas/lapack from system location succeeds.
Next when configure checks the other package from macports location -
the blas from macports gets picked up and fails.
i.e
"gcc -lblas" works.
"gcc -L/opt/macports/lib -lotherpackage -lblas" fails..
Satish
