[petsc-users] Transpose of Block Matrix with aij type
Karl Rupp
rupp at mcs.anl.gov
Tue Apr 23 17:24:38 CDT 2013
Hi again,
if you have control over the structure of B, what about computing
[A1 A2] * [B1 B3; B2 B4]
instead?
Best regards,
Karli
On 04/23/2013 05:17 PM, Choi240 wrote:
> Hi,
> I have to compute multiplication between two block matrices. It should
> be as follows:
> B1 | B2 A1 B1A1+B2A2
> B3 | B4 A2 B3A1+B4A2
> However, I just have A = [A1 A2]. So, I need to get A^T. Is there a way
> I can get the transpose of this block matrix with the MatTranspose()? Or
> do I have to use another function such as MatGetSubMatrices()?
> Thank you,
> Joon
> -------- Original message --------
> Subject: Re: [petsc-users] Transpose of Block Matrix with aij type
> From: Karl Rupp <rupp at mcs.anl.gov>
> To: petsc-users at mcs.anl.gov
> CC: choi240 at purdue.edu
> Hi,
> why would you expect that the transpose of a 3x8 matrix is not a 8x3-matrix?
> Best regards,
> Karli
> On 04/23/2013 03:27 PM, Joon hee Choi wrote:
> > Hello,
> > I tried to get transpose of block matrix(just with aij type), but the
> result was not a block matrix. For example,
> > A =
> > 1 2 3 4 | 4 3 2 1
> > 2 3 4 5 | 5 4 3 2
> > 3 4 5 6 | 6 5 4 3
> > AT(expected) =
> > 1 2 3 4
> > 2 3 4 5
> > 3 4 5 6
> > 4 3 2 1
> > 5 4 3 2
> > 6 5 4 3
> > AT(result) =
> > 1 2 3
> > 2 3 4
> > 3 4 5
> > 4 5 6
> > 4 5 6
> > 3 4 5
> > 2 3 4
> > 1 2 3
> > If someone knows about this problem, please let me know it.
> > Thank you
