[petsc-users] Increasing ILU robustness
Hugo Gagnon
opensource.petsc at user.fastmail.fm
Sun Apr 21 10:38:44 CDT 2013
Linear elasticity, which yields symmetric positive definite matrices. So I guess I could reformulate my question to: what is the solver/preconditioner combination that is "best" suited for this kind of problem? I tried Anton suggestion and gave BCGS a shot but although it does seem to work it converges very slowly. Using the gamg preconditioner blows up:
[0]PCSetData_AGG bs=1 MM=9120
KSP resid. tolerance target = 1.000E-10
KSP initial residual |res0| = 1.443E-01
KSP iter = 0: |res|/|res0| = 1.000E+00
KSP iter = 1: |res|/|res0| = 4.861E-01
KSP Object: 6 MPI processes
type: cg
maximum iterations=10000
tolerances: relative=1e-10, absolute=1e-50, divergence=10000
left preconditioning
using nonzero initial guess
using PRECONDITIONED norm type for convergence test
PC Object: 6 MPI processes
type: gamg
MG: type is MULTIPLICATIVE, levels=2 cycles=v
Cycles per PCApply=1
Using Galerkin computed coarse grid matrices
Coarse grid solver -- level -------------------------------
KSP Object: (mg_coarse_) 6 MPI processes
type: gmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=1, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
using NONE norm type for convergence test
PC Object: (mg_coarse_) 6 MPI processes
type: bjacobi
block Jacobi: number of blocks = 6
Local solve info for each block is in the following KSP and PC objects:
[0] number of local blocks = 1, first local block number = 0
[0] local block number 0
KSP Object: KSP Object: (mg_coarse_sub_) 1 MPI processes
type: preonly
type: preonly
maximum iterations=10000, initial guess is zero
type: preonly
type: preonly
type: preonly
type: preonly
PC Object: (mg_coarse_sub_) 1 MPI processes
type: lu
type: lu
type: lu
LU: out-of-place factorization
type: lu
tolerance for zero pivot 2.22045e-14
matrix ordering: nd
type: lu
matrix ordering: nd
factor fill ratio given 5, needed 0
Factored matrix follows:
Matrix Object: type: lu
matrix ordering: nd
Matrix Object: LU: out-of-place factorization
matrix ordering: nd
matrix ordering: nd
Matrix Object: tolerance for zero pivot 2.22045e-14
matrix ordering: nd
Matrix Object: 1 MPI processes
factor fill ratio given 5, needed 4.41555
type: seqaij
rows=447, cols=447
package used to perform factorization: petsc
total: nonzeros=75113, allocated nonzeros=75113
total number of mallocs used during MatSetValues calls =0
not using I-node routines
linear system matrix = precond matrix:
type: seqaij
rows=447, cols=447
total: nonzeros=17011, allocated nonzeros=17011
1 MPI processes
type: seqaij
rows=0, cols=0
total: nonzeros=1, allocated nonzeros=1
type: seqaij
rows=0, cols=0
total: nonzeros=0, allocated nonzeros=0
1 MPI processes
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
1 MPI processes
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
1 MPI processes
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
type: seqaij
rows=0, cols=0
[1] number of local blocks = 1, first local block number = 1
[1] local block number 0
[2] number of local blocks = 1, first local block number = 2
[2] local block number 0
[3] number of local blocks = 1, first local block number = 3
[3] local block number 0
[4] number of local blocks = 1, first local block number = 4
[4] local block number 0
[5] number of local blocks = 1, first local block number = 5
[5] local block number 0
Matrix Object: 6 MPI processes
type: mpiaij
rows=447, cols=447
not using I-node (on process 0) routines
Down solver (pre-smoother) on level 1 -------------------------------
KSP Object: (mg_levels_1_) 6 MPI processes
type: chebyshev
Chebyshev: eigenvalue estimates: min = 0.0358458, max = 4.60675
maximum iterations=2
PC Object: (mg_levels_1_) 6 MPI processes
type: jacobi
type: mpiaij
rows=54711, cols=54711
total: nonzeros=4086585, allocated nonzeros=4086585
using I-node (on process 0) routines: found 3040 nodes, limit used is 5
Up solver (post-smoother) same as down solver (pre-smoother)
type: mpiaij
Error in FEMesh_Mod::moveFEMeshPETSc() : KSP returned with error code = -8
Hugo Gagnon
On 2013-04-21, at 10:58 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Hugo Gagnon <opensource.petsc at user.fastmail.fm> writes:
>> Hi,
>> I'm getting a KSP_DIVERGED_INDEFINITE_PC error using CG with ILU. I
>> tried increasing the number of levels of fill and also tried other
>> options described in
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCILU.html
>> but without any luck. Are there some other preconditioner options
>> that might work?
> What kind of problem are you solving? How does this work?
> -pc_type gamg -pc_gamg_agg_nsmooths 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130421/a459805c/attachment-0001.html>
