[petsc-users] Increasing ILU robustness
Hugo Gagnon opensource.petsc at user.fastmail.fm
Sat Apr 20 20:53:09 CDT 2013
I'm getting a KSP_DIVERGED_INDEFINITE_PC error using CG with ILU.  I tried increasing the number of levels of fill and also tried other options described in http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCILU.html but without any luck.  Are there some other preconditioner options that might work?  The solution converges nicely with petsc's cg + lu and sparskit2's iluk on an independent cg serial solver.
  Hugo Gagnon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130420/60dd2304/attachment.html>
