[petsc-users] Crash when using valgrind
Dominik Szczerba
dominik at itis.ethz.ch
Fri Apr 19 06:36:00 CDT 2013
On Thu, Apr 18, 2013 at 3:29 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Dominik Szczerba <dominik at itis.ethz.ch> writes:
>>> What happens when you pass -no_signal_handler to the PETSc program?
>> valgrind --tool=memcheck -q --num-callers=20 MySolver -no_signal_handler
>> No change, i.e:
>> cr_libinit.c:183 cri_init: sigaction() failed: Invalid argument
>> Aborted (core dumped)
> Can you run simple BLCR-using programs in Valgrind? You might have to
> do your debugging in a non-BLCR build.
I now found that it seems to be an issue with the system mpich2 that I
am using. Thanks for the pointer.
Dominik
