[petsc-users] Any changes in ML usage between 3.1-p8 -> 3.3-p6?
    Jozsef Bakosi
    jbakosi at lanl.gov
    Wed Apr 17 17:21:03 CDT 2013
> On 04.17.2013 15:38, Matthew Knepley wrote:
> > On 04.17.2013 14:26, Jozsef Bakosi wrote:
> > > Mark F. Adams mark.adams at columbia.edu
> > > Wed Apr 17 14:25:04 CDT 2013
> > > 2) If you get "Indefinite PC" (I am guessing from using CG) it is because the
> > > preconditioner
> > >     really is indefinite (or possible non-symmetric). We improved the checking
> > >     for this in one
> > >     of those releases.
> > > AMG does not guarantee an SPD preconditioner so why persist in trying to use
> > > CG?
> > > AMG is positive if everything is working correctly.
> > > Are these problems only semidefinite?  Singular systems can give erratic
> > > behavior.
> > It is a Laplace operator from Galerkin finite elements. And the PC is fine on
> > ranks 1, 2, 3, and 5 -- indefinite only on 4. I think we can safely say that the
> > same PC should be positive on 4 as well.
> Why is it safe? Because it sounds plausible? Mathematics is replete with things
> that sound plausible and are false. Are there proofs that suggest this? Is there
> computational evidence? Why would I believe you?
Okay, so here is some additional information:
I tried both old and new PETSc versions again, but now only taking 2 iterations
(both with 4 CPUs) and checked the residuals. I get the same exact PC from ML in
both cases, however, the residuals are different after both iterations:
Please do a diff on the attached files and you can verify that the ML
diagnostics are exactly the same: same max eigenvalues, nodes aggregated, etc,
while the norm coming out of the solver at the end at both iterations are
different.
We reproduced the same exact behavior on two different linux platforms.
Once again: same application source code, same ML source code, different PETSc:
3.1-p8 vs. 3.3-p6.
Entering ML_Gen_MGHierarchy_UsingAggregation
* ML Aggregation information                                 *
ML_Aggregate : ordering           = natural.
ML_Aggregate : min nodes/aggr     = 2
ML_Aggregate : max neigh selected = 0
ML_Aggregate : attach scheme      = MAXLINK
ML_Aggregate : strong threshold   = 0.000000e+00
ML_Aggregate : P damping factor   = 1.333333e+00
ML_Aggregate : number of PDEs     = 1
ML_Aggregate : number of null vec = 1
ML_Aggregate : smoother drop tol  = 0.000000e+00
ML_Aggregate : max coarse size    = 250
ML_Aggregate : max no. of levels  = 10
ML_Aggregate_Coarsen (level 0) begins
ML_Aggregate_CoarsenUncoupled : current level = 0
ML_Aggregate_CoarsenUncoupled : current eps = 0.000000e+00
Aggregation(UVB) : Total nonzeros = 6183334 (Nrows=236600)
Aggregation(UC) : Phase 0 - no. of bdry pts  = 0
Aggregation(UC) : Phase 1 - nodes aggregated = 216030 (236600)
Aggregation(UC) : Phase 1 - total aggregates = 9124
Aggregation(UC_Phase2_3) : Phase 1 - nodes aggregated = 216030
Aggregation(UC_Phase2_3) : Phase 1 - total aggregates = 9124
Aggregation(UC_Phase2_3) : Phase 2a- additional aggregates = 0
Aggregation(UC_Phase2_3) : Phase 2 - total aggregates = 9124
Aggregation(UC_Phase2_3) : Phase 2 - boundary nodes   = 0
Aggregation(UC_Phase2_3) : Phase 3 - leftovers = 0 and singletons = 0
Gen_Prolongator (level 0) : Max eigenvalue = 4.2404e+00
Prolongator/Restriction smoother (level 0) : damping factor #1 = 3.1444e-01
Prolongator/Restriction smoother (level 0) : ( = 1.3333e+00 / 4.2404e+00)
ML_Aggregate_Coarsen (level 1) begins
ML_Aggregate_CoarsenUncoupled : current level = 1
Aggregation(UVB) : Total nonzeros = 267508 (Nrows=9124)
Aggregation(UC) : Phase 1 - nodes aggregated = 5944 (9124)
Aggregation(UC) : Phase 1 - total aggregates = 293
Aggregation(UC_Phase2_3) : Phase 1 - nodes aggregated = 5944
Aggregation(UC_Phase2_3) : Phase 1 - total aggregates = 293
Aggregation(UC_Phase2_3) : Phase 2a- additional aggregates = 45
Aggregation(UC_Phase2_3) : Phase 2 - total aggregates = 338
Gen_Prolongator (level 1) : Max eigenvalue = 1.9726e+00
Prolongator/Restriction smoother (level 1) : damping factor #1 = 6.7594e-01
Prolongator/Restriction smoother (level 1) : ( = 1.3333e+00 / 1.9726e+00)
ML_Aggregate_Coarsen (level 2) begins
ML_Aggregate_CoarsenUncoupled : current level = 2
Aggregation(UVB) : Total nonzeros = 12942 (Nrows=338)
Aggregation(UC) : Phase 1 - nodes aggregated = 174 (338)
Aggregation(UC) : Phase 1 - total aggregates = 10
Aggregation(UC_Phase2_3) : Phase 1 - nodes aggregated = 174
Aggregation(UC_Phase2_3) : Phase 1 - total aggregates = 10
Aggregation(UC_Phase2_3) : Phase 2a- additional aggregates = 5
Aggregation(UC_Phase2_3) : Phase 2 - total aggregates = 15
Gen_Prolongator (level 2) : Max eigenvalue = 1.4886e+00
Prolongator/Restriction smoother (level 2) : damping factor #1 = 8.9569e-01
Prolongator/Restriction smoother (level 2) : ( = 1.3333e+00 / 1.4886e+00)
Smoothed Aggregation : operator complexity = 1.045392e+00.
KSP Object:(PPE_)
  type: cg
  maximum iterations=10000
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
  left preconditioning
  using nonzero initial guess
  using UNPRECONDITIONED norm type for convergence test
PC Object:(PPE_)
  type: ml
    MG: type is MULTIPLICATIVE, levels=4 cycles=v
      Cycles per PCApply=1
  Coarse grid solver -- level 0 presmooths=1 postsmooths=1 -----
    KSP Object:(PPE_mg_coarse_)
      type: preonly
      maximum iterations=1, initial guess is zero
      using PRECONDITIONED norm type for convergence test
    PC Object:(PPE_mg_coarse_)
      type: redundant
        Redundant preconditioner: First (color=0) of 4 PCs follows
      KSP Object:(PPE_mg_coarse_redundant_)
        type: preonly
        maximum iterations=10000, initial guess is zero
      PC Object:(PPE_mg_coarse_redundant_)
        type: lu
          LU: out-of-place factorization
          tolerance for zero pivot 2.22045e-16
          matrix ordering: nd
          factor fill ratio given 5, needed 1
            Factored matrix follows:
              Matrix Object:
                type=seqaij, rows=15, cols=15
                package used to perform factorization: petsc
                total: nonzeros=225, allocated nonzeros=225
                  using I-node routines: found 3 nodes, limit used is 5
        linear system matrix = precond matrix:
        Matrix Object:
        type: preonly
        type: lu
          matrix ordering: nd
              Matrix Object:
        Matrix Object:
        type: preonly
        type: lu
          matrix ordering: nd
              Matrix Object:
        Matrix Object:
      Matrix Object:
        type=mpiaij, rows=15, cols=15
          using I-node (on process 0) routines: found 1 nodes, limit used is 5
  Down solver (pre-smoother) on level 1 smooths=1 --------------------
    KSP Object:(PPE_mg_levels_1_)
      type: richardson
        Richardson: damping factor=0.9
      using NO norm type for convergence test
    PC Object:(PPE_mg_levels_1_)
      type: bjacobi
        block Jacobi: number of blocks = 4
        Local solve is same for all blocks, in the following KSP and PC objects:
      KSP Object:(PPE_mg_levels_1_sub_)
        type: preonly
      PC Object:(PPE_mg_levels_1_sub_)
        type: icc
          0 levels of fill
          tolerance for zero pivot 1e-12
          using Manteuffel shift
          matrix ordering: natural
        Matrix Object:
          type=seqaij, rows=81, cols=81
          total: nonzeros=2091, allocated nonzeros=2091
            not using I-node routines
      Matrix Object:
        type=mpiaij, rows=338, cols=338
        total: nonzeros=12942, allocated nonzeros=12942
          not using I-node (on process 0) routines
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 smooths=1 --------------------
    KSP Object:(PPE_mg_levels_2_)
      type: richardson
    PC Object:(PPE_mg_levels_2_)
      type: bjacobi
      KSP Object:(PPE_mg_levels_2_sub_)
        type: preonly
      PC Object:(PPE_mg_levels_2_sub_)
        type: icc
          0 levels of fill
        Matrix Object:
          type=seqaij, rows=2265, cols=2265
          total: nonzeros=60131, allocated nonzeros=60131
      Matrix Object:
        type=mpiaij, rows=9124, cols=9124
        total: nonzeros=267508, allocated nonzeros=267508
  Down solver (pre-smoother) on level 3 smooths=1 --------------------
    KSP Object:(PPE_mg_levels_3_)
      type: richardson
    PC Object:(PPE_mg_levels_3_)
      type: bjacobi
      KSP Object:(PPE_mg_levels_3_sub_)
        type: preonly
      PC Object:(PPE_mg_levels_3_sub_)
        type: icc
          0 levels of fill
        Matrix Object:
          type=seqaij, rows=59045, cols=59045
          total: nonzeros=1504413, allocated nonzeros=1594215
      Matrix Object:
        type=mpiaij, rows=236600, cols=236600
        total: nonzeros=6183334, allocated nonzeros=12776400
  Matrix Object:
    solver: ||b|| = 5.9221e-03
    solver: ||x(0)|| = 0.0000e+00
    solver: Iteration: 1 ||r|| = 3.7007e-03 ||x(i+1)-x(i)|| = 1.2896e+01 ||x(i+1)|| = 1.2896e+01
    solver: Iteration: 2 ||r|| = 2.8927e-03 ||x(i+1)-x(i)|| = 2.8520e+00 ||x(i+1)|| = 1.2444e+01
ML_Gen_MultiLevelHierarchy (level 0) : Gen Restriction and Prolongator
ML_Gen_MultiLevelHierarchy (level 1) : Gen Restriction and Prolongator
ML_Gen_MultiLevelHierarchy (level 2) : Gen Restriction and Prolongator
KSP Object:(PPE_) 4 MPI processes
  type: cg
PC Object:(PPE_) 4 MPI processes
  type: ml
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (PPE_mg_coarse_)     4 MPI processes
      type: preonly
      using NONE norm type for convergence test
    PC Object:    (PPE_mg_coarse_)     4 MPI processes
      type: redundant
      KSP Object:      (PPE_mg_coarse_redundant_)       1 MPI processes
        type: preonly
      PC Object:      (PPE_mg_coarse_redundant_)       1 MPI processes
        type: lu
          matrix ordering: nd
              Matrix Object:               1 MPI processes
                type: seqaij
                rows=15, cols=15
                total number of mallocs used during MatSetValues calls =0
          type: seqaij
          rows=15, cols=15
      Matrix Object:       4 MPI processes
        type: mpiaij
        rows=15, cols=15
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object:    (PPE_mg_levels_1_)     4 MPI processes
      type: richardson
    PC Object:    (PPE_mg_levels_1_)     4 MPI processes
      type: bjacobi
      KSP Object:      (PPE_mg_levels_1_sub_)       1 MPI processes
        type: preonly
      PC Object:      (PPE_mg_levels_1_sub_)       1 MPI processes
        type: icc
          0 levels of fill
          tolerance for zero pivot 2.22045e-14
          type: seqaij
          rows=81, cols=81
        type: mpiaij
        rows=338, cols=338
  Up solver (post-smoother) on level 1 -------------------------------
      type: richardson
      type: bjacobi
        type: preonly
        type: icc
          0 levels of fill
          type: seqaij
          rows=81, cols=81
        type: mpiaij
        rows=338, cols=338
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (PPE_mg_levels_2_)     4 MPI processes
      type: richardson
    PC Object:    (PPE_mg_levels_2_)     4 MPI processes
      type: bjacobi
      KSP Object:      (PPE_mg_levels_2_sub_)       1 MPI processes
        type: preonly
      PC Object:      (PPE_mg_levels_2_sub_)       1 MPI processes
        type: icc
          0 levels of fill
          type: seqaij
        type: mpiaij
  Up solver (post-smoother) on level 2 -------------------------------
      type: richardson
      type: bjacobi
        type: preonly
        type: icc
          0 levels of fill
          type: seqaij
        type: mpiaij
  Down solver (pre-smoother) on level 3 -------------------------------
    KSP Object:    (PPE_mg_levels_3_)     4 MPI processes
      type: richardson
    PC Object:    (PPE_mg_levels_3_)     4 MPI processes
      type: bjacobi
      KSP Object:      (PPE_mg_levels_3_sub_)       1 MPI processes
        type: preonly
      PC Object:      (PPE_mg_levels_3_sub_)       1 MPI processes
        type: icc
          0 levels of fill
          type: seqaij
        type: mpiaij
  Up solver (post-smoother) on level 3 -------------------------------
      type: richardson
      type: bjacobi
        type: preonly
        type: icc
          0 levels of fill
          type: seqaij
        type: mpiaij
    type: mpiaij
    solver: Iteration: 1 ||r|| = 2.2256e-03 ||x(i+1)-x(i)|| = 4.7864e+00 ||x(i+1)|| = 4.7864e+00
    solver: Iteration: 2 ||r|| = 1.4156e-03 ||x(i+1)-x(i)|| = 5.6720e+00 ||x(i+1)|| = 1.0227e+01
