[petsc-users] [MEF-QUAR] Re: Any changes in ML usage between 3.1-p8 -> 3.3-p6?
Matthew Knepley
knepley at gmail.com
Wed Apr 17 14:05:21 CDT 2013
On Wed, Apr 17, 2013 at 12:26 PM, Jozsef Bakosi <jbakosi at lanl.gov> wrote:
> On 04.05.2013 08:34, Jozsef Bakosi wrote:
> > Hi folks,
> > In switching from 3.1-p8 to 3.3-p6, keeping the same ML ml-6.2.tar.gz, I
> get
> > indefinite preconditioner with the newer PETSc version. Has there been
> anything
> > substantial changed around how PCs are handled, e.g. in the defaults?
> > I know this request is pretty general, I would just like to know where
> to start
> > looking, where changes in PETSc might be clobbering the (supposedly same)
> > behavior of ML.
> Alright, here is a little more information about what we see. Running the
> same
> setup/solve using ML (using the same ML and application source code) and
> switching from PETSc 3.1-p8 to 3.3-p6 appears to work differently, in some
> cases, resulting in divergence compared to the old version.
> I attach the output from KSPView() called after KSPSetup() for the 3.1-p8
> (old.out) and for the 3.3-p6 (new.out), both running on 4 MPI ranks.
> A diff reveals some notable differences:
> * using (PRECONDITIONED -> NONE) norm type for convergence test
> * (using -> not using) I-node routines
> * tolerance for zero pivot (1e-12 -> 2.22045e-14) for
> PPE_mg_levels_[12]_sub_
> (stayed the same for PPE_mg_coarse_redundant_)
> So we are wondering what might have changed in the PETSc defaults around
> how
> PCs, in particular ML, is used.
> Thanks, and please let me know if I can give you more information,
1) Please do not give error reports without the full error message
2) If you get "Indefinite PC" (I am guessing from using CG) it is because
the preconditioner
really is indefinite (or possible non-symmetric). We improved the
checking for this in one
of those releases.
AMG does not guarantee an SPD preconditioner so why persist in trying to
use CG?
Matt
> Thanks,
> Jozsef
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130417/057cbe6e/attachment.html>
