[petsc-users] PCView only for one block ?
Mikolaj mikolaj.szydlarski at cea.fr
Tue Apr 16 09:29:34 CDT 2013
Thank you Matt.
I have done what you suggested i.e.,
call PCBJacobiGetSubKSP(pc,nlocal,PETSC_NULL,subksp,ierr)
call KSPView(subksp(1),PETSC_VIEWER_STDOUT_WORLD,ierr)
and it works perfectly.
Mikolaj.
> On Tue, Apr 16, 2013 at 4:05 AM, Mikolaj <mikolaj.szydlarski at cea.fr
> <mailto:mikolaj.szydlarski at cea.fr>> wrote:
>     Hello,
>     I am using a block preconditioners and I wonder if it is possible
>     to print PC data structure for sub-solvers limited only to the one
>     block. By default PCView 'pollute' std output with the information
>     about every single sub-setup from each MPI process ( e.g. below )
>     and I haven't found so far a solution for printing it only from
>     one processor.
> Pull out the subpc you want and call PCView. There is nothing from the
> command line.
>    Matt
>     call PCView(pc,PETSC_VIEWER_STDOUT_WORLD,ierr) after setup of
>     sub-solvers:
>     PC Object: 16 MPI processes
>       type: bjacobi
>         block Jacobi: number of blocks = 16
>         Local solve info for each block is in the following KSP and PC
>     objects:
>       [0] number of local blocks = 1, first local block number = 0
>         [0] local block number 0
>     And then 16 x
>         KSP Object:    (sub_)     1 MPI processes
>           type: preonly
>           maximum iterations=10000, initial guess is zero
>           tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>           left preconditioning
>           using NONE norm type for convergence test
>         PC Object:    (sub_)     1 MPI processes
>           type: ilu
>             ILU: out-of-place factorization
>             1 level of fill
>             tolerance for zero pivot 2.22045e-14
>     Thank you in advance for any hint,
>     best regards,
>     Mikolaj
>     p.s. My petsc version: petsc-3.3-p5 and piece of code for printing:
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130416/760c570b/attachment.html>
