[petsc-users] PCView only for one block ?
Mikolaj
mikolaj.szydlarski at cea.fr
Tue Apr 16 04:05:07 CDT 2013
Hello,
I am using a block preconditioners and I wonder if it is possible to
print PC data structure for sub-solvers limited only to the one block.
By default PCView 'pollute' std output with the information about every
single sub-setup from each MPI process ( e.g. below ) and I haven't
found so far a solution for printing it only from one processor.
call PCView(pc,PETSC_VIEWER_STDOUT_WORLD,ierr) after setup of sub-solvers:
PC Object: 16 MPI processes
type: bjacobi
block Jacobi: number of blocks = 16
Local solve info for each block is in the following KSP and PC objects:
[0] number of local blocks = 1, first local block number = 0
[0] local block number 0
And then 16 x
KSP Object: (sub_) 1 MPI processes
type: preonly
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
left preconditioning
using NONE norm type for convergence test
PC Object: (sub_) 1 MPI processes
type: ilu
ILU: out-of-place factorization
1 level of fill
tolerance for zero pivot 2.22045e-14
Thank you in advance for any hint,
best regards,
Mikolaj
p.s. My petsc version: petsc-3.3-p5 and piece of code for printing:
