[petsc-users] Segfault in DMPlexCreateSectionF90
Tue Apr 16 07:10:20 CDT 2013
On Tue, Apr 16, 2013 at 3:36 AM, Dharmendar Reddy
<dharmareddy84 at gmail.com>wrote:
> Hello,
>           I used the DMPlexCreateSection with Fortran pointers instead of
> allocatable arrays, the code goes past the error in previous error but now
> i get error about the BcPoints IS . Now i printed all the in put data
> before passing to the DMPlexCreateSection, the IS is in a valid state.
> However, i get a error realted to IS. am i doing something wrong here ?
There is an example of this: src/dm/impls/plex/examples/tutorials/ex1f90.F
The problem is that I made this a traditional F77 interface. I will change
it to F90. The problem is that
I cannot be completely consistent since F77 cannot pass back arrays, and
naming all those F90 makes
the interface look horrible. Also, Fortran has no way of telling you that
you are passing the wrong type.
    Matt
> This is the data i pass to the DMPlexCreateSection. Data printed from code
> before calling the createsection. You can see that the number of boundary
> conditions is 2, i have allocated the BcPoints array with index lower bound
> 0 and upper bound 1. Calling ISgetLocalSize and ISView gives no error.
>  dim           1
>  numField           1
>  numComp pointer           1
>  cell DofMap pointer           1           0
>  num BC           2
>  bcField           0           0
>  Check BCPoints Index set for BcPointsIS[           0 ]
>  Number of local points           1
> Number of indices in set 1
> 0 1
>  -----------end IS View----------
>  Check BCPoints Index set for BcPointsIS[           1 ]
> 0 12
> But the call do ISViewGetLocalSize inside the DMPlexCreateSection is
> saying object is in wrong state...
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Invalid argument!
> [0]PETSC ERROR: Wrong type of object: Parameter # 1!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Development GIT revision:
> b6da085e934eddcf71be97425c4be8a7ff05e85d
> GIT Date: 2013-04-15 22:47:22 -0500
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./PoisTest on a mpi_rScalar_Debug named
> login3.stampede.tacc.utexas.edu by
>  Reddy135 Tue Apr 16 03:29:09 2013
> [0]PETSC ERROR: Libraries linked from
> /home1/00924/Reddy135/LocalApps/petsc/mpi_rScalar_De
> bug/lib
> [0]PETSC ERROR: Configure run at Tue Apr 16 01:38:29 2013
> [0]PETSC ERROR: Configure options   --download-blacs=1
> --download-ctetgen=1 --download-met
> is=1 --download-mumps=1 --download-parmetis=1 --download-scalapack=1
> --download-superlu_di
> st=1 --download-triangle=1 --download-umfpack=1
> --with-blas-lapack-dir=/opt/apps/intel/13/
> composer_xe_2013.2.146/mkl/lib/intel64/ --with-debugging=1
> --with-mpi-dir=/opt/apps/intel1
> 3/mvapich2/1.9/ --with-petsc-arch=mpi_rScalar_Debug
> --with-petsc-dir=/home1/00924/Reddy135
> /LocalApps/petsc PETSC_ARCH=mpi_rScalar_Debug
> [0]PETSC ERROR:
> [0]PETSC ERROR: ISGetLocalSize() line 322 in
> /home1/00924/Reddy135/LocalApps/petsc/src/vec
> /is/is/interface/index.c
> [0]PETSC ERROR: DMPlexCreateSectionBCDof() line 5937 in
> tsc/src/dm/impls/plex/plex.c
> [0]PETSC ERROR: DMPlexCreateSection() line 6149 in
> On Tue, Apr 16, 2013 at 2:52 AM, Dharmendar Reddy <dharmareddy84 at gmail.com
> > wrote:
>> Hello,
>>          I am getting a segfault in DMPlexcreateSectionF90 ...I am not
>> sure if the problem is in parameters i pass or it is coming from
>> petsc...can you help me fix this ?
>> Here is the output from debugger:
>> I print the variables passed to function before call and they seem
>> consistent with the format required by the DMPlexCreateSectionF90 call...
>> Breakpoint 1.1, FEMLIB_M::setupdefualtsection_dofmap (this=0x2781e28) at
>> /home1/00924/R
>> eddy135/projects/utgds/src/fem/VariationalProblemBoundProcedures.F90:197
>> 197       call DMPlexCreateSectionF90(this%mdata%Meshdm,this%tdim,
>> this%numField, &
>> (idb) s
>> 198            this%numComp,this%cellDofMap, this%numBC, this%bcFieldId,
>> (idb) s
>> 199            this%bcPointIS,section,ierr)
>> (idb) print this%tdim
>> $25 = 1
>> (idb) print this%numField
>> $26 = 1
>> (idb) print this%numcomp
>> $27 = 1
>> (idb) print this%cellDofMap
>> $28 = {1, 0}
>> (idb) print this%numBC
>> $29 = 2
>> (idb) c
>> Continuing.
>> Breakpoint 1.2, FEMLIB_M::setupdefualtsection_dofmap (this=0x2781e28) at
>> /home1/00924/R
>> this%numField, &
>> (idb) c
>> Continuing.
>> Breakpoint 1.3, FEMLIB_M::setupdefualtsection_dofmap (this=0x2781e28) at
>> /home1/00924/R
>> this%numField, &
>> (idb) c
>> Continuing.
>> Now i see a segfault in inside the petsc call
>> Program received signal SIGSEGV
>> DMPlexCreateSectionInitial (dm=0x281cfa0, dim=1, numFields=1,
>> numComp=0x43ce7cf20000000
>> 1, numDof=0x1, section=0x7fffa07c8d28) at
>> /home1/00924/Reddy135/LocalApps/petsc/src/dm/
>> impls/plex/plex.c:5892
>> 5892        for (f = 0; f < numFields; ++f) numDofTot[d] +=
>> numDof[f*(dim+1)+d];
>> why is the adress of numDof 0x1 ? some thing wrong in the FortranAddress
>> conversion code in zplexf90 ?
>> here is the backtrace
>> #0  0x00002b79e6cec09a in DMPlexCreateSectionInitial (dm=0x281cfa0,
>> dim=1, numFields=1,
>>  numComp=0x43ce7cf200000001, numDof=0x1, section=0x7fffa07c8d28) at
>> /home1/00924/Reddy1
>> 35/LocalApps/petsc/src/dm/impls/plex/plex.c:5892
>> #1  0x00002b79e6cf1038 in DMPlexCreateSection (dm=0x281cfa0, dim=1,
>> numFields=1, numCom
>> p=0x43ce7cf200000001, numDof=0x1, numBC=2, bcField=0xc420000000000000,
>> bcPoints=0xc4200
>> 00002a66e21, section=0x7fffa07c8d28) at
>> /home1/00924/Reddy135/LocalApps/petsc/src/dm/im
>> pls/plex/plex.c:6148
>> #2  0x00002b79e6d9e571 in dmplexcreatesectionf90_ (dm=0x259bda8,
>> dim=0x2781e8c, numFiel
>> ds=0x2781e90, ptrC=0x25ed9e0, ptrD=0x28adf00, numBC=0x27820a0,
>> ptrF=0x25eda00, ptrP=0x2
>> 878900, section=0x7fffa07c8d28, __ierr=0x7fffa07c8c98) at
>> ps/petsc/src/dm/impls/plex/f90-custom/zplexf90.c:221
>> Dharmendar Reddy Palle
>> Graduate Student
>> Microelectronics Research center,
>> University of Texas at Austin,
>> 10100 Burnet Road, Bldg. 160
>> MER 2.608F, TX 78758-4445
>> e-mail: dharmareddy84 at gmail.com
>> Phone: +1-512-350-9082
>> United States of America.
>> Homepage: https://webspace.utexas.edu/~dpr342
> Graduate Student
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130416/fa669a8d/attachment.html>
