[petsc-users] DMPlex<Vec,Mat>SetClosure
Mon Apr 15 19:41:06 CDT 2013
On Mon, Apr 15, 2013 at 7:36 PM, Dharmendar Reddy
<dharmareddy84 at gmail.com>wrote:
> I did realize that after some digging. I fixed that part. Thanks for the
> updates to dmsneslocal.
> If i am on the branch next, do i get access to all the changes you push to
> knepley/plex ?
Yes, once I merge it into next.
  Matt
> On Mon, Apr 15, 2013 at 7:20 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Sat, Apr 13, 2013 at 9:51 PM, Dharmendar Reddy <
>> dharmareddy84 at gmail.com> wrote:
>>> Hello,
>>>          Got it. I understand the reason for errors. I was using
>>> XXXSetF90 functions in my code so i was using allocatable arrays. I thought
>>> all set/getvlaues had corresponding F90 functions. I was trying to define
>>> and use things consistently in the code.
>>> I can fix the compile errors using pointers now.
>>> Now, can i request for Fortran interface for DMPlexMatSetClosure ?
>> Pushed.
>>> will you be adding Fortran interfaces to  the functions listed below ?
>>> FEMModules.F90:(.text+0xbfe0): undefined reference to
>>> `dmplexgetdefaultsection_'
>> This is just DMGetDefaultSection().
>>    Matt
>>> FEMModules.F90:(.text+0xc048): undefined reference to
>>> `petscsectiongetconstraintdof_
>>> Solver.F90:(.text+0xaa1): undefined reference to
>>> `dmsnessetjacobianlocal_'
>>> Solver.F90:(.text+0xabc): undefined reference to
>>> `dmsnessetfunctionlocal_'
>>> Thanks
>>> Reddy
>>> On Sat, Apr 13, 2013 at 9:32 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Sat, Apr 13, 2013 at 9:18 PM, Dharmendar Reddy <
>>>>> I am getting bunch of erros in my code related to DMPlex
>>>>> If i use DMPlexVecSetClosure I get the following error.
>>>>> A pointer dummy argument may only be argument associated with a
>>>>> pointer.   [FELM]
>>>>>     call
>>>>> DMPlexVecSetClosure(dm,PETSC_NULL_OBJECT,F,cellId,Felm,ADD_VALUES,ierr)
>>>>> Felm is defined as  : PetscScalar,allocatable :: Felm(:)
>>>> Did you look at the sample code?
>>>> http://www.mcs.anl.gov/petsc/petsc-dev/src/dm/impls/plex/examples/tests/ex2f90.F.html
>>>> You define pointers. You can see what function I have defined by
>>>> looking at the header
>>>> https://bitbucket.org/petsc/petsc/src/62a20339e027b37fab44424f1466054586f1dc85/include/finclude/ftn-custom/petscdmplex.h90?at=master
>>>> and its clear from the file that DMPlexMatSetClosure() has not been
>>>> defined in Fortran.
>>>>    Matt
>>>>> I do a similar call to DMPlexMatSetClosure, i get no error.
>>>>> Now if i use DMPlexVecSetClosureF90, code compiles, but i see
>>>>> undefined reference error during link stage:
>>>>> FEMModules.F90:(.text+0xba77): undefined reference to
>>>>> `dmplexvecsetclosuref90_'
>>>>> FEMModules.F90:(.text+0xbea9): undefined reference to
>>>>> `dmplexmatsetclosure_'
>>>>> On Sat, Apr 13, 2013 at 8:22 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Sat, Apr 13, 2013 at 8:20 PM, Dharmendar Reddy <
>>>>>>> Hello,
>>>>>>>         I am getting an undefined reference error ::
>>>>>>> `dmplexmatsetclosuref90_'
>>>>>>> I can see that DMPlexVecSetClosure is defined in
>>>>>>> /finclude/ftn-custom/petscdmplex.h90:159:
>>>>>>> but the name is DMPlexVecSetClosure instead of
>>>>>>> DMPlexVecSetClosureF90.
>>>>>>> And there is no DMPlexMatSetClosureF90
>>>>>>> What should i do ?
>>>>>> I was not consistent here with the naming. Since an F77 version was
>>>>>> not possible, I did not
>>>>>> add F90. That is probably wrong, however I would like to scrap the
>>>>>> F77 version of Plex since
>>>>>> everyone uses F90 now and the extra letters are annoying. Go ahead
>>>>>> and use the function.
>>>>>>     Matt
>>>>>>> Thanks
>>>>>>> Reddy
>>>>>>> Dharmendar Reddy Palle
>>>>>>> Graduate Student
>>>>>>> Microelectronics Research center,
>>>>>>> University of Texas at Austin,
>>>>>>> 10100 Burnet Road, Bldg. 160
>>>>>>> MER 2.608F, TX 78758-4445
>>>>>>> e-mail: dharmareddy84 at gmail.com
>>>>>>> Phone: +1-512-350-9082
>>>>>>> United States of America.
>>>>>>> Homepage: https://webspace.utexas.edu/~dpr342
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> Graduate Student
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Graduate Student
>> experiments lead.
>> -- Norbert Wiener
> Graduate Student
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130415/cf6fa854/attachment.html>
