[petsc-users] AOApplicationToPetscIS
Hui Zhang mike.hui.zhang at hotmail.com
Mon Apr 15 15:10:12 CDT 2013
On Apr 15, 2013, at 9:10 PM, Hui Zhang wrote:
> On Apr 15, 2013, at 5:55 PM, Matthew Knepley wrote:
>> On Mon, Apr 15, 2013 at 10:52 AM, Hui Zhang <mike.hui.zhang at hotmail.com> wrote:
>> I'm implementing a domain decomposition preconditioner.  The dof is ordered by myapp and using AO (and LocalToGlobalMapping for assembly) to map to petsc ordering.
>> The task I'm doing is building VecScatter's from subdomains to the global domain.  So my program is
>> I do not understand why you would need AOs for this. They are for global reordering, whereas you seem to only
>> need a local mapping here.
> To use
> 	ISLocalToGlobalMappingCreate(MPI_Comm cm,PetscInt n,const PetscInt indices[],PetscCopyMode mode,ISLocalToGlobalMapping *mapping)
> In the manual page, it says "Not Collective, but communicator may have more than one process".  What is the purpose of using a communicator other than SELF_COMM? Will the input indices[] be gathered in the communicator 'cm'?
> Now I understand why AOCreateBasic is not scalable.  But I still need to use it in the beginning for construction of LocalToGlobalMapping.  How did you implement the LocalToGlobalMapping for element-based decomposition?  Did you avoid using any AO?
I think I find a way.  I can use GetOwnerShipRanges, the mesh element connectivity and mesh processor connectivity.   AO is too global for this-- it does not take advantage of the connectivity but a global search.
>>   Matt
>> Step 1.  I can map subdomain petsc ordering to subdomain natural ordering.
>> Step 2.  I can also map subdomain natural ordering to global domain natural ordering.
>> Step 3.  I have an AO for mapping global domain natural ordering to petsc ordering.
>> Since each subdomain is defined on a sub-communicator of the communicator of the global domain.  My question is for
>> AOApplicationToPetscIS(AO ao,IS is)
>> can ao and is have different communicators?  Will my program be bad for large problems?  How would you do it?
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
