[petsc-users] algorithm to get pure real eigen valule for general eigenvalue problem(Non-hermitian type)
Zhang Wei
zhang.wei at chalmers.se
Mon Apr 15 09:50:25 CDT 2013
Hi
Since the case is not that big(size of matrix is 9600x9600. ). I have done test in the first way, which gives me a 2.1 Gb ASCII file. The eigen values I get from matlab are :
> In eigs>processEUPDinfo at 1340
In eigs at 357
>> c
c =
0
0
0
0
1.9405 - 0.4733i
1.9405 + 0.4733i
And what I got from slepc are :
0 1.99988
1 1.99974
2 1.99971
3 1.99913+0.0370552j
4 1.99913+-0.0370552j
5 1.99894+0.0370115j
Non of them is right one. And on the other hand there are lots of small values in the matrix which are almost in order of 1e-7 and even smaller.
Could it be the reason resulting such problem?
-----Original Message-----
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Jose E. Roman
Sent: den 15 april 2013 11:44
To: PETSc users list
Subject: Re: [petsc-users] algorithm to get pure real eigen valule for general eigenvalue problem(Non-hermitian type)
El 15/04/2013, a las 11:28, Zhang Wei escribió:
> Hi
> Sorry I forgot to say it is matrix free case. So if I can export matrix like that? Or any another way to do so?
> Yours Sincerely
> Wei Zhang
> Ph.D
> Hydrodynamic Group
> Dept. of Shipping and Marine Technology Chalmers University of
> Technology Sweden
> Phone:+46-31 772 2703
You could run the SLEPc program with "-eps_type lapack", then a dense matrix will be created using matrix-vector products (you will see it if you set the -mat_view_matlab flag). This is very rudimentary and only viable for very small dimension. A better alternative would be to call MatComputeExplicitOperator() from within your code, use a binary viewer to save the resulting matrix and load it in Matlab with PetscBinaryRead.m.
Jose
