[petsc-users] How to get the eigenvectors in Slepc
Karl Rupp rupp at mcs.anl.gov
Mon Apr 15 06:56:14 CDT 2013
Hi Sonya,
I really suggest you familiarize yourself with eigenvalues and
eigenvectors. For each eigenvector v, alpha*v is also an eigenvector to
the same eigenvalue, where alpha can be any nonzero scalar. If the sign
doesn't fit your expectations, just multiply it with -1. :-)
Best regards,
Karli
On 04/15/2013 04:02 AM, Sonya Blade wrote:
> Even If I have normalization at the exact solution this doesn't explain
> how the sign of it has changed, as a result square roots of sum of squares
> can never have negative value (vector length).
> Basically what I need to do, to get the Slepc results matching with the exact ones.
> Do I need to call any function before Slepc normalizes them or something else?
> Regards,
