[petsc-users] algorithm to get pure real eigen valule for general eigenvalue problem(Non-hermitian type)
Zhang Wei
zhang.wei at chalmers.se
Mon Apr 15 04:28:47 CDT 2013
Hi
Sorry I forgot to say it is matrix free case. So if I can export matrix like that? Or any another way to do so?
Yours Sincerely
Wei Zhang
Ph.D
Hydrodynamic Group
Dept. of Shipping and Marine Technology
Chalmers University of Technology
Sweden
Phone:+46-31 772 2703
On 14 apr 2013, at 22:54, "Jose E. Roman" <jroman at dsic.upv.es> wrote:
> El 14/04/2013, a las 19:51, Zhang Wei escribió:
>> Hi!
>> Thanks for your reply. I am now dealing with non symmetric eigen problem, where I expect to get these complex pairs. I am looking for the largest magnitude eigen pairs. But I always get many pure real eigen pairs,which in my case make no sense. The thing is that these are not totally wrong.since it is a standard case I compared with others, these real eigen values are somehow close to the magnitude of "correct" results.for eigen vectors, the "correct" results can be express as "T*exp(kx)",where the T is chebyshev polynomial. And all real eigen vectors I got are extract chebyshev polynomial. Actually I already set the problem to NHEP,and can get some complex eigen pairs. Comparing with expected one those eigen values are larger in angle. On the other hand I set the tolerance to 1e-9.
>> Thanks in advance!
> Are you completely sure that your matrix is being formed correctly? I would suggest running a small example with -mat_view_matlab then load the matrix and try eigs(A) in Matlab to make sure you get the expected results.
> Jose
