[petsc-users] Seq vs MPI convergence
Jed Brown
jedbrown at mcs.anl.gov
Sun Apr 14 17:23:15 CDT 2013
Hugo Gagnon <opensource.petsc at user.fastmail.fm> writes:
> Hi,
> I have a problem that converges fine in sequential mode but diverges
> in MPI (other problems seem to converge fine for both modes). I am no
> expert in parallel solvers but, is this something I should expect?
> I'm using BiCGSTAB with BJACOBI ILU(3). Perhaps I'm overseeing some
> parameters that could improve my convergences?
The most common problem is that you assemble a different operator in
parallel. So check that and check that you get the same answer when
using redundant solves.
-pc_type redundant -redundant_pc_type ilu
