[petsc-users] How to get the eigenvectors in Slepc
Jose E. Roman
jroman at dsic.upv.es
Sun Apr 14 09:44:13 CDT 2013
El 14/04/2013, a las 08:04, Sonya Blade escribió:
> Dear All,
> If I have all eigenvalues as real numbers is it possible mathematically that
> I get the complex eigenvectors? Because nowhere in my solution I obtain the
> complex eigenvalues but Slepc returns the complex for eigenvectors.
> Your enlightenment will be appreciated.
> Regards,
If the eigenvector is complex then of course the eigenvalue is complex as well (I assume your matrix is real non-symmetric). You have to get both the real and imaginary parts of the eigenvalue.
http://www.grycap.upv.es/slepc/documentation/current/docs/manualpages/EPS/EPSGetEigenpair.html
An alternative is to do all the computation in complex arithmetic (configure --with-scalar-type=complex).
Jose
