[petsc-users] Assembly of local Mat's to a parallel Mat
Jed Brown
jedbrown at mcs.anl.gov
Fri Apr 12 12:10:35 CDT 2013
Hui Zhang <mike.hui.zhang at hotmail.com> writes:
> On Apr 12, 2013, at 5:22 PM, Jed Brown wrote:
> I can understand this method. A further question: since Ai itself is shared
> by many processors, MatSetValues to A should be called by only one of the
> processor sharing Ai. Is it right?
If your Ai are already shared, why can't you just start by creating the
big block-diagonal system containing all the Ai along the diagonal?
Then MatGetSubMatrix() will give you the part if you really need to do
something separate with it.
>> or you can create a block diagonal parallel
>> matrix A_i constructed by joining together all the diagonal blocks.
> Which function can do this? I only found diagonal block Mat with each block
> of the same size and dense. Thanks!
There is no function to do it in-place, but you can just create the big
matrix and loop through the small matrix inserting rows. It's usually
better to start with the big matrix.
