[petsc-users] Assembly of local Mat's to a parallel Mat
Hui Zhang
mike.hui.zhang at hotmail.com
Fri Apr 12 11:49:12 CDT 2013
On Apr 12, 2013, at 5:22 PM, Jed Brown wrote:
> Hui Zhang <mike.hui.zhang at hotmail.com> writes:
>> Assembly it directly. I just found MatGetSubMatricesParallel.
> This is not a private implementation function so it's not a good place
> to learn. It also doesn't do what you want.
> For your purpose, you can either loop over the entries of A_i inserting
> them according to the R_i
I can understand this method. A further question: since Ai itself is shared
by many processors, MatSetValues to A should be called by only one of the
processor sharing Ai. Is it right?
> or you can create a block diagonal parallel
> matrix A_i constructed by joining together all the diagonal blocks.
Which function can do this? I only found diagonal block Mat with each block
of the same size and dense. Thanks!
> Presumably R is already parallel, so then you can use MatPtAP to
> assemble the product.
> Note that you might be able to assemble the block diagonal A directly.
>> Maybe I can learn from the source codes of this function but I can not
>> find where they are.
> For navigating source code, see the manual section about setting up GNU
> Global tags or etags. PETSc functions are named to tab complete well
> with tags.
