[petsc-users] Problem with petsc-dev+openmpi
Zhang
zyzhang at nuaa.edu.cn
Wed Apr 10 09:07:04 CDT 2013
I installed petsc-dev. Everything thing's fine when compiling it.
But problems appeared with the downloaded openmpi-1.6.3 when I make /ksp/ex2 and ran by
mpirun -n 2 ex2
Errors as follows,
It looks like orte_init failed for some reason; your parallel process is
likely to abort. There are many reasons that a parallel process can
fail during orte_init; some of which are due to configuration or
environment problems. This failure appears to be an internal failure;
here's some additional information (which may only be relevant to an
Open MPI developer):
orte_util_nidmap_init failed
--> Returned value Data unpack would read past end of buffer (-26) instead of ORTE_SUCCESS
[ubuntu:03237] [[3831,1],0] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file util/nidmap.c at line 118
[ubuntu:03237] [[3831,1],0] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ess_env_module.c at line 174
orte_ess_set_name failed
[ubuntu:03237] [[3831,1],0] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file runtime/orte_init.c at line 128
It looks like MPI_INIT failed for some reason; your parallel process is
fail during MPI_INIT; some of which are due to configuration or environment
problems. This failure appears to be an internal failure; here's some
additional information (which may only be relevant to an Open MPI
developer):
ompi_mpi_init: orte_init failed
--> Returned "Data unpack would read past end of buffer" (-26) instead of "Success" (0)
[ubuntu:3237] *** An error occurred in MPI_Init_thread
[ubuntu:3237] *** on a NULL communicator
[ubuntu:3237] *** Unknown error
[ubuntu:3237] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
An MPI process is aborting at a time when it cannot guarantee that all
of its peer processes in the job will be killed properly. You should
double check that everything has shut down cleanly.
Reason: Before MPI_INIT completed
Local host: ubuntu
PID: 3237
[ubuntu:03240] [[3831,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file util/nidmap.c at line 118
[ubuntu:03240] [[3831,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ess_env_module.c at line 174
[ubuntu:03240] [[3831,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file runtime/orte_init.c at line 128
mpirun has exited due to process rank 0 with PID 3237 on
node ubuntu exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[ubuntu:03236] 1 more process has sent help message help-orte-runtime.txt / orte_init:startup:internal-failure
[ubuntu:03236] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
[ubuntu:03236] 1 more process has sent help message help-orte-runtime / orte_init:startup:internal-failure
[ubuntu:03236] 1 more process has sent help message help-mpi-runtime / mpi_init:startup:internal-failure
[ubuntu:03236] 1 more process has sent help message help-mpi-errors.txt / mpi_errors_are_fatal unknown handle
[ubuntu:03236] 1 more process has sent help message help-mpi-runtime.txt / ompi mpi abort:cannot guarantee all killed
Please help solve this, and many thanks
Zhenyu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130410/de55c685/attachment.html>
