[petsc-users] EVP Solutions with Subspace
Sonya Blade
sonyablade2010 at hotmail.com
Fri Apr 5 12:12:00 CDT 2013
>By default SLEPc uses a direct solver, so you would not get this message. Which options are you using for the KSP?
>Jose
I use Subspace if you mean that by option. Probably I'm misinterpreting
something here. As far as I know KSP stands for the Kyrlov subspace, can
you guide me on that?
ierr = EPSCreate(PETSC_COMM_WORLD,&eps);CHKERRQ(ierr);
ierr = EPSSetDimensions(eps,12,PETSC_NULL,PETSC_NULL);
ierr = EPSSetType(eps, EPSSUBSPACE);
ierr = EPSSetOperators(eps,B,C);CHKERRQ(ierr);
ierr = EPSSetProblemType(eps,EPS_GNHEP);CHKERRQ(ierr);
Set the initial vector. This is optional, if not done the initial
vector is set to random values
ierr = MatGetVecs(B,&v0,PETSC_NULL);CHKERRQ(ierr);
ierr = VecSet(v0,1.0);CHKERRQ(ierr);
ierr = EPSSetInitialSpace(eps,1,&v0);CHKERRQ(ierr);
/* - - - Solve the eigensystem - - - */
ierr = EPSSolve(eps);CHKERRQ(ierr);
