[petsc-users] Petsc/Slepc Integration with Code Blocks IDE
Sonya Blade
sonyablade2010 at hotmail.com
Mon Apr 1 04:03:08 CDT 2013
Dear All,
Does any of you succeed to integrate Code Blocks IDE with Petsc and SLepc? I've tried this
with configuring properly the compiler, linker path, header files and feeding with libraries
namely "libslepc.a" and "libpetsc.a" but still compiler complains for some of the missing routines.
I gave below couple of errors if it makes you recall anything.
Your help will be appreciated.
/cygdrive/D/TEST_FOLDER_dell/slepc/src/vec/contiguous.c:186: undefined reference to `_dgemm_'
/cygdrive/D/TEST_FOLDER_dell/slepc/src/vec/contiguous.c:199: undefined reference to `_dgemm_'
../../../slepc/arch-mswin-c-debug/lib/libslepc.a(contiguous.c.o): In function `SlepcUpdateStrideVectors':
/cygdrive/D/TEST_FOLDER_dell/slepc/src/vec/contiguous.c:391: undefined reference to `_dgemm_'
/cygdrive/D/TEST_FOLDER_dell/slepc/src/vec/contiguous.c:401: undefined reference to `_dgemm_'
../../../slepc/arch-mswin-c-debug/lib/libslepc.a(contiguous.c.o): In function `SlepcVecMAXPBY':
/cygdrive/D/TEST_FOLDER_dell/slepc/src/vec/contiguous.c:455: undefined reference to `_MPI_Allreduce'
/cygdrive/D/TEST_FOLDER_dell/slepc/src/vec/contiguous.c:456: undefined reference to `_MPI_Allreduce'
/cygdrive/D/TEST_FOLDER_dell/slepc/src/vec/contiguous.c:457: undefined reference to `_MPI_Allreduce'
/cygdrive/D/TEST_FOLDER_dell/slepc/src/vec/contiguous.c:463: undefined reference to `_MPI_Comm_compare'
/cygdrive/D/TEST_FOLDER_dell/slepc/src/vec/contiguous.c:475: undefined reference to `_dgemv_'
../../../slepc/arch-mswin-c-debug/lib/libslepc.a(basic.c.o): In function `EPSView':
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/interface/basic.c:144: undefined reference to `_MPI_Comm_compare'
../../../slepc/arch-mswin-c-debug/lib/libslepc.a(basic.c.o): In function `EPSPrintSolution':
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/interface/basic.c:344: undefined reference to `_MPI_Comm_compare'
../../../slepc/arch-mswin-c-debug/lib/libslepc.a(basic.c.o): In function `EPSSetTarget':
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/interface/basic.c:728: undefined reference to `_MPI_Allreduce'
../../../slepc/arch-mswin-c-debug/lib/libslepc.a(basic.c.o): In function `EPSSetInterval':
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/interface/basic.c:798: undefined reference to `_MPI_Allreduce'
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/interface/basic.c:799: undefined reference to `_MPI_Allreduce'
../../../slepc/arch-mswin-c-debug/lib/libslepc.a(basic.c.o): In function `EPSSetST':
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/interface/basic.c:864: undefined reference to `_MPI_Comm_compare'
../../../slepc/arch-mswin-c-debug/lib/libslepc.a(basic.c.o): In function `EPSSetIP':
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/interface/basic.c:931: undefined reference to `_MPI_Comm_compare'
../../../slepc/arch-mswin-c-debug/lib/libslepc.a(basic.c.o): In function `EPSSetDS':
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/interface/basic.c:997: undefined reference to `_MPI_Comm_compare'
../../../slepc/arch-mswin-c-debug/lib/libslepc.a(dvd_blas.c.o): In function `SlepcDenseMatProd':
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/impls/davidson/common/dvd_blas.c:81: undefined reference to `_dgemm_'
../../../slepc/arch-mswin-c-debug/lib/libslepc.a(dvd_blas.c.o): In function `SlepcDenseMatProdTriang':
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/impls/davidson/common/dvd_blas.c:157: undefined reference to `_dsymm_'
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/impls/davidson/common/dvd_blas.c:170: undefined reference to `_dsymm_'
../../../slepc/arch-mswin-c-debug/lib/libslepc.a(dvd_blas.c.o): In function `SlepcDenseNorm':
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/impls/davidson/common/dvd_blas.c:205: undefined reference to `_dnrm2_'
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/impls/davidson/common/dvd_blas.c:206: undefined reference to `_dnrm2_'
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/impls/davidson/common/dvd_blas.c:208: undefined reference to `_dscal_'
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/impls/davidson/common/dvd_blas.c:209: undefined reference to `_dscal_'
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/impls/davidson/common/dvd_blas.c:212: undefined reference to `_dnrm2_'
/cygdrive/D/TEST_FOLDER_dell/slepc/src/eps/impls/davidson/common/dvd_blas.c:214: undefined reference to `_dscal_'
