[petsc-users] MPI Derived Data Type and Non Blocking MPI Send/Recieve
Alan Wei zhenglun.wei at gmail.com
Sat Sep 8 12:59:50 CDT 2012
Thank you soooooo much, Dr. Brown. It fixed my problem. I really appreciate
your time and help. :)
thank you again,
Alan
On Fri, Sep 7, 2012 at 9:20 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>    if(!localBC.tBC) {
>       MPI_Isend(&_TestV[0][_Index.tcEnd-1][0], 1, columntype, NbrRank.t,
> SendTag.T1st, PETSC_COMM_WORLD, &request);
>       MPI_Isend(&_TestV[0][_Index.tcEnd][0], 1, columntype, NbrRank.t,
> SendTag.T2nd, PETSC_COMM_WORLD, &request);
>     if(!localBC.bBC) {
>       MPI_Isend(&_TestV[0][_Index.bcStr+1][0], 1, columntype, NbrRank.b,
> SendTag.B1st, PETSC_COMM_WORLD, &request);
>       MPI_Isend(&_TestV[0][_Index.bcStr][0], 1, columntype, NbrRank.b,
> SendTag.B2nd, PETSC_COMM_WORLD, &request);
>     MPI_Barrier(PETSC_COMM_WORLD);
>     printf("Rank = %d finished sending!!!\n", rank);
>     if(!localBC.tBC) {
>       MPI_Irecv(&_TestV[0][_Index.tbStr+1][0], 1, columntype, NbrRank.t,
> RecvTag.T2nd, PETSC_COMM_WORLD, &request);
>       MPI_Irecv(&_TestV[0][_Index.tbStr][0], 1, columntype,  NbrRank.t,
> RecvTag.T1st, PETSC_COMM_WORLD, &request);
>     if(!localBC.bBC) {
>       MPI_Irecv(&_TestV[0][_Index.bbEnd-1][0], 1, columntype, NbrRank.b,
> RecvTag.B2nd, PETSC_COMM_WORLD, &request);
>       MPI_Irecv(&_TestV[0][_Index.bbEnd][0], 1, columntype, NbrRank.b,
> RecvTag.B1st, PETSC_COMM_WORLD, &request);
>     MPI_Wait(&request, &status);
> You are creating far more requests than you are waiting on. You need to
> keep track of *every* request and eventually wait on all of them.
> It is generally better for performance to post the receives first, then
> post the sends, then MPI_Waitall() on all the requests.
> On Fri, Sep 7, 2012 at 4:50 PM, Zhenglun (Alan) Wei <
> zhenglun.wei at gmail.com> wrote:
>>  Dear folks,
>>      I did more tests, since I want to make sure where I'm wrong.
>>      As Dr. Smith suggested, I tested my code using OpenMPI and MPICH.
>> Both of them have the memory accumulation problem. Therefore, I suppose
>> there is a bug in my code. I went into the code, and changed the
>> non-blocking MPI communication to blocking one. The memory accumulation
>> problem is just gone by itself. However, I have to change it back since the
>> blocking MPI communication does not allow me to do massive data
>> communication. Now, I'm searching for related topics on non-blocking MPI
>> communication.
>>      Here I cut off those unrelated part of my code and attach the
>> communication part here. Could anyone help me to briefly check if there is
>> any obvious mistake I made in the program? After unzip the file,
>> './AlanRun' will execute the program.
>> I really appreciate your help :)
>> Alan
>> On 9/6/2012 5:56 PM, Jed Brown wrote:
>> Numeric data that the solver sees should be stored in Vecs. You can put
>> other scalars in Vecs if you like.
>> On Sep 6, 2012 5:48 PM, "Zhenglun (Alan) Wei" <zhenglun.wei at gmail.com>
>> wrote:
>>>  Dear Dr. Brown,
>>>      I'm not quite familiar with VecScatter. I just read its
>>> explanation; it seems requires that my data is stored as a form of vectors
>>> (is it the vector in PETSc?). However, my data are stored as arrays in C
>>> program.
>>>      Is that any problem in MPI or it is likely a problem of my code?
>>> thanks,
>>> Alan
>>> On 9/6/2012 5:44 PM, Jed Brown wrote:
>>> Are you familiar with VecScatter?
>>> On Sep 6, 2012 5:38 PM, "Zhenglun (Alan) Wei" <zhenglun.wei at gmail.com>
>>> wrote:
>>>> Dear All,
>>>>      I hope you're having a nice day.
>>>>      I met a memory problem for MPI data communication. I guess here is
>>>> a good place to ask this question since you guys are experts and may
>>>> experienced the same problem before.
>>>>      I used the MPI derived data type (MPI_Type_contiguous,
>>>> MPI_Type_vector and MPI_Type_indexed) to communicate data for a simulation
>>>> of 3D problem. The communication is fine, as I checked every single data it
>>>> sent and received. However, the problem is that the memory keeps increasing
>>>> while communication. Therefore, I tested each of these three types.
>>>> MPI_Type_contiguous does not have any problem; while MPI_Type_vector and
>>>> MPI_Type_indexed have problem of memory accumulation. I tried to use
>>>> MPI_Type_free, but it does not help. Have anyone experienced this problem
>>>> before?
>>>>      Would this be related to the non-blocking MPI communication
>>>> (MPI_Isend and MPI_Irecv). I have to use this non-blocking communication
>>>> since the blocking communication is extremely slow when it has a lot of
>>>> data involved in the communication.
>>>>      Is there any alternative way in PETSc that could do the similar
>>>> work of MPI derived types?
>>>> thanks,
>>>> Alan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120908/fb8ea621/attachment.html>
