[petsc-users] How rto use multigrid?
TAY wee-beng
zonexo at gmail.com
Tue Oct 30 17:34:28 CDT 2012
On 30/10/2012 1:44 PM, Matthew Knepley wrote:
> On Tue, Oct 30, 2012 at 7:41 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
> On 28/10/2012 2:17 PM, Jed Brown wrote:
>> Algebraic multigrid can be used directly, -pc_type gamg
>> -pc_gamg_agg_nsmooths 1. Geometric either required that you use
>> the PCMG interface to set interpolation (and provide a coarse
>> operator for non-Galerkin) or use a DM that provides coarsening
>> capability.
>> What kind of problem are you solving?
> Hi,
> May I know if there is an example which explains using the
> geometric MG, either using PCMG or DM?
> SNES ex5 and ex19 both use MG.
> Matt
Are there examples which uses ksp and geometric MG? I want to solve a
Poisson eqn which has been discretized to give a sys of linear eqns.
I also found this thread :
http://lists.mcs.anl.gov/pipermail/petsc-users/2012-August/015073.html
Is it using geometric MG to solve a sys of linear eqns?
> Yours sincerely,
> TAY wee-beng
>> On Oct 28, 2012 6:09 AM, "w_ang_temp" <w_ang_temp at 163.com
>> <mailto:w_ang_temp at 163.com>> wrote:
>> Hello,
>> I want to use the multigrid as a preconditioner. The
>> introduction about it in the manual is little.
>> So are there some typical examples or details about
>> multigrid? Is it used just like other preconditioners
>> like jacobi, sor, which can be simply used in the cammand
>> line options?
>> Thanks.
>> Jim
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121030/3441df46/attachment.html>
