[petsc-users] How rto use multigrid?
TAY wee-beng zonexo at gmail.com
Tue Oct 30 06:41:33 CDT 2012
On 28/10/2012 2:17 PM, Jed Brown wrote:
> Algebraic multigrid can be used directly, -pc_type gamg
> -pc_gamg_agg_nsmooths 1. Geometric either required that you use the
> PCMG interface to set interpolation (and provide a coarse operator for
> non-Galerkin) or use a DM that provides coarsening capability.
> What kind of problem are you solving?
May I know if there is an example which explains using the geometric MG,
either using PCMG or DM?
Yours sincerely,
TAY wee-beng
> On Oct 28, 2012 6:09 AM, "w_ang_temp" <w_ang_temp at 163.com
> <mailto:w_ang_temp at 163.com>> wrote:
>     Hello,
>        I want to use the multigrid as a preconditioner. The
>     introduction about it in the manual is little.
>     So are there some typical examples or details about multigrid? Is
>     it used just like other preconditioners
>     like jacobi, sor, which can be simply used in the cammand line
>     options?
>        Thanks.
>     Jim
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121030/d6471c30/attachment.html>
