[petsc-users] Trying to run ex11 (complex example) in $PETSC_DIR/src/ksp/ksp/examples/tutorials
Moore, Brian (SDSU) Brian.Moore at sdstate.edu
Mon Oct 29 16:08:41 CDT 2012
Apologies--probably should have done this before I posted the question.
I just downloaded and compiled the latest development version this afternoon and was successfully able to run this example.
Brian Moore, Research High Performance Computing Specialist
SDSU UNSS
SAD 119, Box 2201, Brookings, SD  57007-1598
605.688.4679 (wk) / 605.521.3062 (cell)
On Oct 29, 2012, at 3:29 PM, Moore, Brian (SDSU) wrote:
I am trying to make a build of petsc that will enable complex numbers.  As per the manual in Sec. 13.7, I did a ./configure as:
./configure --download-f-blas-lapack=1 --with-shared-libraries=1 --download-mpich --with-scalar-type=complex
and then tried to compile and make the ex11 example program from $PETSC_DIR/src/ksp/ksp/examples/tutorials
The error I am seeing is listed below.  Does anyone have an idea what the problem is?  I was able to run several of the other example programs in this folder (ex1, ex2, ex23) and was able to run the fortran program ex11f.
Thanks.
SDSU UNSS
moore at moore-pc2:~/petsc-3.3-p4/src/ksp/ksp/examples/tutorials> make runex11
1,8c1,20
<   0 KSP Residual norm 4.62271
<   1 KSP Residual norm 1.58711
<   2 KSP Residual norm 0.767563
<   3 KSP Residual norm 0.472102
<   4 KSP Residual norm 0.435655
<   5 KSP Residual norm 0.154866
<   6 KSP Residual norm < 1.e-11
< Norm of error < 1.e-12 iterations 6
> 1+1i
> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: Object is in wrong state!
> [0]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on argument 1 "mat" before MatGetOwnershipRange()!
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 4, Fri Oct 26 10:46:51 CDT 2012
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: ./ex11 on a arch-linu named moore-pc2 by moore Mon Oct 29 15:27:59 2012
> [0]PETSC ERROR: Libraries linked from /home/moore/petsc-3.3-p4/arch-linux2-c-debug/lib
> [0]PETSC ERROR: Configure run at Mon Oct 29 15:00:29 2012
> [0]PETSC ERROR: Configure options --download-f-blas-lapack=1 --with-shared-libraries=1 --download-mpich --with-scalar-type=complex
> [0]PETSC ERROR: MatGetOwnershipRange() line 5992 in /home/moore/petsc-3.3-p4/src/mat/interface/matrix.c
> [0]PETSC ERROR: main() line 83 in src/ksp/ksp/examples/tutorials/ex11.c
> application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
> [cli_0]: aborting job:
/home/moore/petsc-3.3-p4/src/ksp/ksp/examples/tutorials
Possible problem with with ex11_1, diffs above \n=========================================
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121029/40b01e2b/attachment.html>
