[petsc-users] How rto use multigrid?
    w_ang_temp
    w_ang_temp at 163.com
    Sun Oct 28 08:38:40 CDT 2012
Hello, Jed
    Thanks for your timely reply. I deal with the soil-water coupled problem in geotechnical engineering,
whose stiffness matrix is ill-conditioned. I have did some work about it, mainly finding the effective
solvers and preconditioners. I used the command line option like this:
mpiexec -n 4 ./ex4f -ksp_type cgs -pc_type sor -ksp_rtol 1.0e-15 -ksp_converged_reason.
    So, I also want to use the multigrid just like the simple command. There is only a little introduction
about multigrid in the manual. Multigrid is complex and not a easy thing for me, so I just need to konw how
to use it simply in PETSc to solve the Ax=b system.
    Thanks.
                                                               Jim
>At 2012-10-28 21:17:00,"Jed Brown" <jedbrown at mcs.anl.gov> wrote:
>Algebraic multigrid can be used directly, -pc_type gamg -pc_gamg_agg_nsmooths 1. Geometric either required that you use the PCMG interface to set >interpolation (and provide a coarse operator for non-Galerkin) or use a DM that provides coarsening capability.
>What kind of problem are you solving?
>>On Oct 28, 2012 6:09 AM, "w_ang_temp" <w_ang_temp at 163.com> wrote:
>>Hello,
>>   I want to use the multigrid as a preconditioner. The introduction about it in the manual is little.
>>So are there some typical examples or details about multigrid? Is it used just like other preconditioners
>>like jacobi, sor, which can be simply used in the cammand line options?
>>   Thanks.
>>        Jim
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121028/0acc607d/attachment.html>
